| | File and Print Sharing Problem. I’m running the Windows Vista Business edition operating system on which I’m trying to install a product during the installation of which I get the error message. " The Microsoft File and Print Sharing Service must be installed and running on this machine in order to install SQL express.Please contact your Network administrator to install and/or enable this service." I have ensured that all the Sections for File Sharing and Printer Sharing are enabled in the Network Centre. Also the File and Printer Sharing Service has been installed and enabled [has a tick mark] on the Network adapter. I have also ensured that the “Server Service” is running under services.msc. Could you please assist me further as to what best can be done in order that the product can be installed fine? P.S:- Im running VISTA on VMWARE.That makes it a Virtual Machine.Any thoughts??? |
| | Re: File and Print Sharing Problem. Kiran wrote: > I’m running the Windows Vista Business edition operating system on which I’m > trying to install a product during the installation of which I get the error > message. > " The Microsoft File and Print Sharing Service must be installed and running > on this machine in order to install SQL express.Please contact your Network > administrator to install and/or enable this service." > I have ensured that all the Sections for File Sharing and Printer Sharing > are enabled in the Network Centre. Also the File and Printer Sharing Service > has been installed and enabled [has a tick mark] on the Network adapter. I > have also ensured that the “Server Service” is running under services.msc. > Could you please assist me further as to what best can be done in order that > the product can be installed fine? > > P.S:- Im running VISTA on VMWARE.That makes it a Virtual Machine.Any > thoughts??? You need to contact the makers of whatever product you're trying to install. A tailored SQL Express is obviously part of their product (like ACT has) and it (and the main product) may not be Vista-compatible. The product's tech support should know this, have any workarounds or patches, and know whether their software will work in a VM. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: File and Print Sharing Problem. Right you are Malke; You hit the nail on the Head. Thank you for your suggestions. Im next going to try and install the software on a standalone Physical PC and check if that gives any relief.I was of the impression that since it throws up an error with respect to File and Print Sharing, it should indeed be a Windows OS issue. Could IPv6 or LLTD installed on the VMWare adapter be a cause for concern? Kiran. "Malke" wrote: > Kiran wrote: > > I’m running the Windows Vista Business edition operating system on which I’m > > trying to install a product during the installation of which I get the error > > message. > > " The Microsoft File and Print Sharing Service must be installed and running > > on this machine in order to install SQL express.Please contact your Network > > administrator to install and/or enable this service." > > I have ensured that all the Sections for File Sharing and Printer Sharing > > are enabled in the Network Centre. Also the File and Printer Sharing Service > > has been installed and enabled [has a tick mark] on the Network adapter. I > > have also ensured that the “Server Service” is running under services.msc. > > Could you please assist me further as to what best can be done in order that > > the product can be installed fine? > > > > P.S:- Im running VISTA on VMWARE.That makes it a Virtual Machine.Any > > thoughts??? > > You need to contact the makers of whatever product you're trying to > install. A tailored SQL Express is obviously part of their product (like > ACT has) and it (and the main product) may not be Vista-compatible. The > product's tech support should know this, have any workarounds or > patches, and know whether their software will work in a VM. > > > Malke > -- > Elephant Boy Computers > www.elephantboycomputers.com > "Don't Panic!" > MS-MVP Windows - Shell/User > |
| | Re: File and Print Sharing Problem. Kiran wrote: > Right you are Malke; You hit the nail on the Head. Thank you for your > suggestions. > Im next going to try and install the software on a standalone Physical PC > and check if that gives any relief.I was of the impression that since it > throws up an error with respect to File and Print Sharing, it should indeed > be a Windows OS issue. Could IPv6 or LLTD installed on the VMWare adapter be > a cause for concern? I can't answer that question. The only people who can answer that are the people who make whatever program is in question. Call their tech support and ask them about your issues with their software. I would not assume that the issue lies with the operating system but rather question whether the unnamed program correctly interacts with Vista. Only the unnamed program's tech support people will know. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: File and Print Sharing Problem. Hey Malke, Looks like we finally have a solution to that annoying problem.It is to disable the UAC in User Accounts. Thanks for all UR valuable suggestions. Thanks and Regards, Kiran. "Malke" wrote: > Kiran wrote: > > Right you are Malke; You hit the nail on the Head. Thank you for your > > suggestions. > > Im next going to try and install the software on a standalone Physical PC > > and check if that gives any relief.I was of the impression that since it > > throws up an error with respect to File and Print Sharing, it should indeed > > be a Windows OS issue. Could IPv6 or LLTD installed on the VMWare adapter be > > a cause for concern? > > I can't answer that question. The only people who can answer that are > the people who make whatever program is in question. Call their tech > support and ask them about your issues with their software. I would not > assume that the issue lies with the operating system but rather question > whether the unnamed program correctly interacts with Vista. Only the > unnamed program's tech support people will know. > > > Malke > -- > Elephant Boy Computers > www.elephantboycomputers.com > "Don't Panic!" > MS-MVP Windows - Shell/User > |
| vista file and print sharing | Vista networking & sharing | |||
| File and Print sharing in Vista | Vista networking & sharing | |||
| File and print sharing uninstalls after rebooting | Vista networking & sharing | |||
| Why do file and print sharing work and then fail? | Vista networking & sharing | |||
| File and Print sharing not working. | Vista networking & sharing | |||
