Vista - DVI to HDMI connection - but no sound
Old 04-11-2007   #1 (permalink)
Bobby
I had a problem connecting my Vista PC to my LCD HD TV using the DMI
connections on both (the TV's DMI connection was flakey) and so purchased a
DVI to HDMI cable, connecting the DVI output of the PC to the HDMI input of
the TV.
This works fine - for video - but I get no sound.
I appreciate that my PC's DMI output does not carry a sound signal but I
haven't touched the PC audio out to my TV audio in connection - which worked
fine when it was DMI to DMI but is now silenced when it is DMI to HDMI. How
come?
Is there a fix - or have I wasted my money buying this new cable?
Cheers.
Bobby
HDMI to amp no sound Sound & Audio
Optical or HDMI to amp for sound? Sound & Audio
No sound from TV with HDMI cable Sound & Audio
Surround Sound option Grayed out with HD4870 and HDMI connection Sound & Audio
no sound through hdmi?? Sound & Audio
