| | Boot Problem: System Partition Hi all, I'd been running Vista fine for about a week and a half on a new Dell Dimension E520 desktop. This morning, I woke up to a System Recovery screen. I've been unable to get Vista start. When I try to run Startup Repair, I get the error: "The partition table does not have a valid System Partition." Also, when trying to select an operating system to repair, I cannot see Windows Vista (nor can I find the driver). Any suggestions would be gratefully accepted. Thanks. |
| | Re: Boot Problem: System Partition Hi, Sounds like the hard drive is damaged. You will need to contact Dell as the system is probably still under warranty and this work will require a technician unless you are familiar with replacing drives and have recovery media that came separately on a CD. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "VistaConfusion" <VistaConfusion@discussions.microsoft.com> wrote in message news:EEA90F02-0D7C-4A56-BF1E-2021D34C2BB1@microsoft.com... > Hi all, > > I'd been running Vista fine for about a week and a half on a new Dell > Dimension E520 desktop. This morning, I woke up to a System Recovery > screen. > I've been unable to get Vista start. When I try to run Startup Repair, I > get > the error: > > "The partition table does not have a valid System Partition." > > Also, when trying to select an operating system to repair, I cannot see > Windows Vista (nor can I find the driver). > > Any suggestions would be gratefully accepted. > > Thanks. |
| VISTA HOME PREMIUM - unable to extend a non system/boot partition | Vista General | |||
| How to install vista in system and boot partition | General Discussion | |||
| OT: Boot issues after Ghost System Partition Restore to New Hard Drive | Vista General | |||
| Boot Issue Moving Vista Partition to new system | Vista installation & setup | |||
| Allow GPT Partition for Boot Partition (not System Partition) | Vista installation & setup | |||
