| | SQL Management Studio in Vista Ultimate Hi, I'm having problems installing SQL Management Studio in Windows Vista. I'm using a SQL Server DVD to install only the Management Tools When I try to install I get this error message: "Error 1706: Setup cannot find the required files. Check your connection to the network, or CD-ROM drive. For other potential solutions to this problem, see C:\Program Files\Microsoft Office\OFFICE11\1033\SETUP.CHM." When setup finishes, it shows an error icon next to OWC11 and Worstation Components and there's no "SQL Management Studio" icon in the start menu. I've already tried to use SP2 installable to install. It does the same thing. Anyone knows how to install this in Windows Vista? Thank you -- [ TaeB ] |
| | RE: SQL Management Studio in Vista Ultimate Hello Victor, Thank you for using newsgroup! From your post, it seems the issue is related to SQL Management Studio setup in Windows Vista. I suggest you post to Microsoft.public.sqlserver.setup newsgroup where other peers will provide you with the information or experience. Thanks for your understanding. Thanks & Regards, Ken Zhao Microsoft Online Support Microsoft Global Technical Support Center Get Secure! - www.microsoft.com/security <http://www.microsoft.com/security> ==================================================== When responding to posts, please "Reply to Group" via your newsreader so that others may learn and benefit from your issue. ==================================================== This posting is provided "AS IS" with no warranties, and confers no rights. -------------------- | From: "Victor Turegano" <taeb@noemail.noemail> | Subject: SQL Management Studio in Vista Ultimate | Date: Thu, 12 Apr 2007 11:03:53 -0500 | Lines: 21 | MIME-Version: 1.0 | Content-Type: text/plain; | format=flowed; | charset="iso-8859-1"; | reply-type=original | Content-Transfer-Encoding: 7bit | X-Priority: 3 | X-MSMail-Priority: Normal | X-Newsreader: Microsoft Windows Mail 6.0.6000.16386 | X-MimeOLE: Produced By Microsoft MimeOLE V6.0.6000.16386 | Message-ID: <Ov$WmwRfHHA.4868@TK2MSFTNGP06.phx.gbl> | Newsgroups: microsoft.public.windows.vista.general | NNTP-Posting-Host: dsl-189-141-54-100.prod-infinitum.com.mx 189.141.54.100 | Path: TK2MSFTNGHUB02.phx.gbl!TK2MSFTNGP01.phx.gbl!TK2MSFTNGP06.phx.gbl | Xref: TK2MSFTNGHUB02.phx.gbl microsoft.public.windows.vista.general:82219 | X-Tomcat-NG: microsoft.public.windows.vista.general | | Hi, I'm having problems installing SQL Management Studio in Windows Vista. | I'm using a SQL Server DVD to install only the Management Tools | | When I try to install I get this error message: "Error 1706: Setup cannot | find the required files. Check your connection to the network, or CD-ROM | drive. For other potential solutions to this problem, see C:\Program | Files\Microsoft Office\OFFICE11\1033\SETUP.CHM." | | When setup finishes, it shows an error icon next to OWC11 and Worstation | Components and there's no "SQL Management Studio" icon in the start menu. | | I've already tried to use SP2 installable to install. It does the same | thing. | | Anyone knows how to install this in Windows Vista? | | Thank you | | -- | [ TaeB ] | | |
| Visual Studio fails on Vista Ultimate | Vista General | |||
| Vista Ultimate x64 vs. Borland Developer Studio 2006 | Vista General | |||
| Vista Ultimate x64 vs. Borland Developer Studio 2006 | Vista installation & setup | |||
| Visual Studio 2005 on Vista Ultimate | Vista General | |||
| Can't install SQL Express management studio | Vista General | |||
