| | Will not auto-sleep Vista will not go to sleep automatically. The screen turn dark but machine will not sleeep. Even after a clean re-start. If I manually press the sleep button on the keyboard it works fine. Why will it not auto-sleep |
| | Re: Will not auto-sleep On 4/12/2007 12:00 PM On a whim, Paul pounded out on the keyboard > Vista will not go to sleep automatically. The screen turn dark but machine > will not sleeep. Even after a clean re-start. > > If I manually press the sleep button on the keyboard it works fine. > > Why will it not auto-sleep You need a bigger sledge hammer ;-) Check the power settings to verify the length of time before sleep is to occur. Is this an upgraded computer or a new computer? Possibly legacy hardware is preventing it also. -- Terry ***Reply Note*** Anti-spam measures are included in my email address. Delete NOSPAM from the email address after clicking Reply. |
| | Re: Will not auto-sleep If I set it to 2 minutes or 1 hours it does not matter. It is a brand new Vista based PC. Infact I have 4 of them! "Terry" wrote: > On 4/12/2007 12:00 PM On a whim, Paul pounded out on the keyboard > > > Vista will not go to sleep automatically. The screen turn dark but machine > > will not sleeep. Even after a clean re-start. > > > > If I manually press the sleep button on the keyboard it works fine. > > > > Why will it not auto-sleep > > You need a bigger sledge hammer ;-) > > Check the power settings to verify the length of time before sleep is to > occur. Is this an upgraded computer or a new computer? Possibly legacy > hardware is preventing it also. > > -- > Terry > > ***Reply Note*** > Anti-spam measures are included in my email address. > Delete NOSPAM from the email address after clicking Reply. > |
| | Re: Will not auto-sleep On 4/12/2007 2:40 PM On a whim, Paul pounded out on the keyboard > If I set it to 2 minutes or 1 hours it does not matter. > > It is a brand new Vista based PC. Infact I have 4 of them! > > "Terry" wrote: > >> On 4/12/2007 12:00 PM On a whim, Paul pounded out on the keyboard >> >>> Vista will not go to sleep automatically. The screen turn dark but machine >>> will not sleeep. Even after a clean re-start. >>> >>> If I manually press the sleep button on the keyboard it works fine. >>> >>> Why will it not auto-sleep >> You need a bigger sledge hammer ;-) >> >> Check the power settings to verify the length of time before sleep is to >> occur. Is this an upgraded computer or a new computer? Possibly legacy >> hardware is preventing it also. >> It could be a program that is running. I would start looking at programs that you have installed. see what ones run processes and disable them one at a time see if you can track down what it is. It could also be a driver problem. I'm not sure if power settings are active in Safe Mode, but try it and see if sleep occurs in Safe Mode. If it does, it is probably a driver preventing it. -- Terry ***Reply Note*** Anti-spam measures are included in my email address. Delete NOSPAM from the email address after clicking Reply. |
| | Re: Will not auto-sleep If I click the sleep button it sleeps. It I let it do it automatically it does not. same programs must be running. I can re-boot and not open anything and the result is the same. "Terry" wrote: > On 4/12/2007 2:40 PM On a whim, Paul pounded out on the keyboard > > > If I set it to 2 minutes or 1 hours it does not matter. > > > > It is a brand new Vista based PC. Infact I have 4 of them! > > > > "Terry" wrote: > > > >> On 4/12/2007 12:00 PM On a whim, Paul pounded out on the keyboard > >> > >>> Vista will not go to sleep automatically. The screen turn dark but machine > >>> will not sleeep. Even after a clean re-start. > >>> > >>> If I manually press the sleep button on the keyboard it works fine. > >>> > >>> Why will it not auto-sleep > >> You need a bigger sledge hammer ;-) > >> > >> Check the power settings to verify the length of time before sleep is to > >> occur. Is this an upgraded computer or a new computer? Possibly legacy > >> hardware is preventing it also. > >> > > It could be a program that is running. I would start looking at > programs that you have installed. see what ones run processes and > disable them one at a time see if you can track down what it is. It > could also be a driver problem. I'm not sure if power settings are > active in Safe Mode, but try it and see if sleep occurs in Safe Mode. > If it does, it is probably a driver preventing it. > > -- > Terry > > ***Reply Note*** > Anti-spam measures are included in my email address. > Delete NOSPAM from the email address after clicking Reply. > |
| | #6 (permalink) |
| | Re: Will not auto-sleep Do you have you sidebar up? And if so do you have the analog clock? That kept my machine from sleeping or in fact going into the screen saver... Francois "Paul" <Paul@discussions.microsoft.com> wrote in message news:AF8AB10E-0029-49CB-9F88-B248D86029CC@microsoft.com... > If I click the sleep button it sleeps. It I let it do it automatically it > does not. same programs must be running. > > I can re-boot and not open anything and the result is the same. > > "Terry" wrote: > >> On 4/12/2007 2:40 PM On a whim, Paul pounded out on the keyboard >> >> > If I set it to 2 minutes or 1 hours it does not matter. >> > >> > It is a brand new Vista based PC. Infact I have 4 of them! >> > >> > "Terry" wrote: >> > >> >> On 4/12/2007 12:00 PM On a whim, Paul pounded out on the keyboard >> >> >> >>> Vista will not go to sleep automatically. The screen turn dark but >> >>> machine >> >>> will not sleeep. Even after a clean re-start. >> >>> >> >>> If I manually press the sleep button on the keyboard it works fine. >> >>> >> >>> Why will it not auto-sleep >> >> You need a bigger sledge hammer ;-) >> >> >> >> Check the power settings to verify the length of time before sleep is >> >> to >> >> occur. Is this an upgraded computer or a new computer? Possibly >> >> legacy >> >> hardware is preventing it also. >> >> >> >> It could be a program that is running. I would start looking at >> programs that you have installed. see what ones run processes and >> disable them one at a time see if you can track down what it is. It >> could also be a driver problem. I'm not sure if power settings are >> active in Safe Mode, but try it and see if sleep occurs in Safe Mode. >> If it does, it is probably a driver preventing it. >> >> -- >> Terry >> >> ***Reply Note*** >> Anti-spam measures are included in my email address. >> Delete NOSPAM from the email address after clicking Reply. >> |
| | #7 (permalink) |
| | Re: Will not auto-sleep I turned off the Media Cener's updates and that seems to have done the trick (so far) "Francois" wrote: > Do you have you sidebar up? And if so do you have the analog clock? > > That kept my machine from sleeping or in fact going into the screen saver... > > Francois > > > "Paul" <Paul@discussions.microsoft.com> wrote in message > news:AF8AB10E-0029-49CB-9F88-B248D86029CC@microsoft.com... > > If I click the sleep button it sleeps. It I let it do it automatically it > > does not. same programs must be running. > > > > I can re-boot and not open anything and the result is the same. > > > > "Terry" wrote: > > > >> On 4/12/2007 2:40 PM On a whim, Paul pounded out on the keyboard > >> > >> > If I set it to 2 minutes or 1 hours it does not matter. > >> > > >> > It is a brand new Vista based PC. Infact I have 4 of them! > >> > > >> > "Terry" wrote: > >> > > >> >> On 4/12/2007 12:00 PM On a whim, Paul pounded out on the keyboard > >> >> > >> >>> Vista will not go to sleep automatically. The screen turn dark but > >> >>> machine > >> >>> will not sleeep. Even after a clean re-start. > >> >>> > >> >>> If I manually press the sleep button on the keyboard it works fine. > >> >>> > >> >>> Why will it not auto-sleep > >> >> You need a bigger sledge hammer ;-) > >> >> > >> >> Check the power settings to verify the length of time before sleep is > >> >> to > >> >> occur. Is this an upgraded computer or a new computer? Possibly > >> >> legacy > >> >> hardware is preventing it also. > >> >> > >> > >> It could be a program that is running. I would start looking at > >> programs that you have installed. see what ones run processes and > >> disable them one at a time see if you can track down what it is. It > >> could also be a driver problem. I'm not sure if power settings are > >> active in Safe Mode, but try it and see if sleep occurs in Safe Mode. > >> If it does, it is probably a driver preventing it. > >> > >> -- > >> Terry > >> > >> ***Reply Note*** > >> Anti-spam measures are included in my email address. > >> Delete NOSPAM from the email address after clicking Reply. > >> > > |
| | #8 (permalink) |
| Vista Ultimate x64 | Re: Will not auto-sleep Following things helped me out: Turn off auto updates (Start -> control panel -> security center -> automatic updating: change settings: turn off) Turn off steam or msn. Hope this helps for others? |
| Vista won't auto sleep after SP1 | Vista General | |||
| auto standby instead of auto sleep | Vista General | |||
| No Auto Sleep - Manual Sleep OK | Vista General | |||
| Visa will not auto-sleep | Vista General | |||
| Auto Sleep and Screen turn off. | Vista General | |||
