| Guest | 43 GB System File in System Volume Information on 160 GB partition (1) File name: {ca0a01b4-d58c-11db-8afb-0013720efba8}{3808876b-c176-4e48-b7ae-04046e6cc752}. (2) Partition is NOT System partition. (3) System Restore on this partition was ENabled by default, but is now DISabled. (4) File is modified after each boot. (System log entry nearest to Date/Time Modified is Windows Modules Installer service entering stopped state.) A single file consuming over 25% of a partition seems excessive. Any ideas? TIA. |
| Guest | Re: 43 GB System File in System Volume Information on 160 GB partition Brent Run Disk CleanUp, More, Options, System Restore. What affect does it have on the file size? -- Hope this helps. Gerry ~~~~ FCA Stourport, England Enquire, plan and execute ~~~~~~~~~~~~~~~~~~~ "Brent" <HarvestThis@Spammers.Net> wrote in message news:%23LxvtSUfHHA.4868@TK2MSFTNGP06.phx.gbl... > (1) File name: > {ca0a01b4-d58c-11db-8afb-0013720efba8}{3808876b-c176-4e48-b7ae-04046e6cc752}. > > (2) Partition is NOT System partition. > > (3) System Restore on this partition was ENabled by default, but > is now > DISabled. > > (4) File is modified after each boot. (System log entry nearest to > Date/Time Modified is Windows Modules Installer service entering > stopped > state.) > > A single file consuming over 25% of a partition seems excessive. > Any > ideas? > > TIA. > > |
| Guest | Re: 43 GB System File in System Volume Information on 160 GB partition Should have mentioned that I already tried that, to no avail. Thanks for responding. "Gerry Cornell" <gcjcvis@nospam.com> wrote in message news:%23Oq%23GjVfHHA.208@TK2MSFTNGP05.phx.gbl... > Brent > > Run Disk CleanUp, More, Options, System Restore. What affect does it > have on the file size? > > -- > > > Hope this helps. > > Gerry > ~~~~ > FCA > Stourport, England > Enquire, plan and execute > ~~~~~~~~~~~~~~~~~~~ > > > "Brent" <HarvestThis@Spammers.Net> wrote in message > news:%23LxvtSUfHHA.4868@TK2MSFTNGP06.phx.gbl... >> (1) File name: >> {ca0a01b4-d58c-11db-8afb-0013720efba8}{3808876b-c176-4e48-b7ae-04046e6cc752}. >> >> (2) Partition is NOT System partition. >> >> (3) System Restore on this partition was ENabled by default, but is >> now >> DISabled. >> >> (4) File is modified after each boot. (System log entry nearest to >> Date/Time Modified is Windows Modules Installer service entering >> stopped >> state.) >> >> A single file consuming over 25% of a partition seems excessive. Any >> ideas? >> >> TIA. >> >> > |
| Guest | Re: 43 GB System File in System Volume Information on 160 GB partition Brent What is the file extension? Have you searched your registry using regedit to see if the guid (if that is what they are?) appears in the registry to get a programme name? -- Hope this helps. Gerry ~~~~ FCA Stourport, England Enquire, plan and execute ~~~~~~~~~~~~~~~~~~~ "Brent" <HarvestThis@Spammers.Net> wrote in message news:%23u6vtsWfHHA.4156@TK2MSFTNGP02.phx.gbl... > Should have mentioned that I already tried that, to no avail. > > Thanks for responding. > > > "Gerry Cornell" <gcjcvis@nospam.com> wrote in message > news:%23Oq%23GjVfHHA.208@TK2MSFTNGP05.phx.gbl... >> Brent >> >> Run Disk CleanUp, More, Options, System Restore. What affect does >> it have on the file size? >> >> -- >> >> >> Hope this helps. >> >> Gerry >> ~~~~ >> FCA >> Stourport, England >> Enquire, plan and execute >> ~~~~~~~~~~~~~~~~~~~ >> >> >> "Brent" <HarvestThis@Spammers.Net> wrote in message >> news:%23LxvtSUfHHA.4868@TK2MSFTNGP06.phx.gbl... >>> (1) File name: >>> {ca0a01b4-d58c-11db-8afb-0013720efba8}{3808876b-c176-4e48-b7ae-04046e6cc752}. >>> >>> (2) Partition is NOT System partition. >>> >>> (3) System Restore on this partition was ENabled by default, but >>> is now >>> DISabled. >>> >>> (4) File is modified after each boot. (System log entry nearest >>> to >>> Date/Time Modified is Windows Modules Installer service entering >>> stopped >>> state.) >>> >>> A single file consuming over 25% of a partition seems excessive. >>> Any >>> ideas? >>> >>> TIA. >>> >>> >> > |
| Guest | Re: 43 GB System File in System Volume Information on 160 GB partition It is a System File with NO extension. Your excellent suggestion about the registry search turned up: HKLM\SYSTEM\CurrentControlSet\Control\BackupRestore\FilesNotToBackup\VSS Default Provider with a value of \System Volume Information\*{3808876B-C176-4e48-B7AE-04046E6CC752} /s Obviously SVI files ending with {3808876B-C176-4e48-B7AE-04046E6CC752} are not to be backed up by Volume Shadow copy Service, but beyond that I'm clueless. The other 2 partitions, System and Users, have 4 and 31 files, respectively, in System Volume Information ending with {3808876B-C176-4e48-B7AE-04046E6CC752} and varying in size from 30 MB to 5.5 GB. Thanks for the assistance. "Gerry Cornell" <gcjcvis@nospam.com> wrote in message news:OJB5RfZfHHA.1456@TK2MSFTNGP04.phx.gbl... > Brent > > What is the file extension? > > Have you searched your registry using regedit to see if the guid (if > that is what they are?) appears in the registry to get a programme > name? > > -- > > > Hope this helps. > > Gerry > ~~~~ > FCA > Stourport, England > Enquire, plan and execute > ~~~~~~~~~~~~~~~~~~~ > > "Brent" <HarvestThis@Spammers.Net> wrote in message > news:%23u6vtsWfHHA.4156@TK2MSFTNGP02.phx.gbl... >> Should have mentioned that I already tried that, to no avail. >> >> Thanks for responding. >> >> >> "Gerry Cornell" <gcjcvis@nospam.com> wrote in message >> news:%23Oq%23GjVfHHA.208@TK2MSFTNGP05.phx.gbl... >>> Brent >>> >>> Run Disk CleanUp, More, Options, System Restore. What affect does it >>> have on the file size? >>> >>> -- >>> >>> >>> Hope this helps. >>> >>> Gerry >>> ~~~~ >>> FCA >>> Stourport, England >>> Enquire, plan and execute >>> ~~~~~~~~~~~~~~~~~~~ >>> >>> >>> "Brent" <HarvestThis@Spammers.Net> wrote in message >>> news:%23LxvtSUfHHA.4868@TK2MSFTNGP06.phx.gbl... >>>> (1) File name: >>>> {ca0a01b4-d58c-11db-8afb-0013720efba8}{3808876b-c176-4e48-b7ae-04046e6cc752}. >>>> >>>> (2) Partition is NOT System partition. >>>> >>>> (3) System Restore on this partition was ENabled by default, but is >>>> now >>>> DISabled. >>>> >>>> (4) File is modified after each boot. (System log entry nearest to >>>> Date/Time Modified is Windows Modules Installer service entering >>>> stopped >>>> state.) >>>> >>>> A single file consuming over 25% of a partition seems excessive. >>>> Any >>>> ideas? >>>> >>>> TIA. >>>> >>>> >>> >> > |
| | #6 (permalink) |
| Guest | Re: 43 GB System File in System Volume Information on 160 GB partition Brent You can control the size of System Restore folders without turning off System Restore. http://bertk.mvps.org/html/diskspacev.html -- Hope this helps. Gerry ~~~~ FCA Stourport, England Enquire, plan and execute ~~~~~~~~~~~~~~~~~~~ "Brent" <HarvestThis@Spammers.Net> wrote in message news:eHISqyZfHHA.928@TK2MSFTNGP02.phx.gbl... > It is a System File with NO extension. > > Your excellent suggestion about the registry search turned up: > > HKLM\SYSTEM\CurrentControlSet\Control\BackupRestore\FilesNotToBackup\VSS > Default Provider > > with a value of > > \System Volume Information\*{3808876B-C176-4e48-B7AE-04046E6CC752} > /s > > Obviously SVI files ending with > {3808876B-C176-4e48-B7AE-04046E6CC752} are not to be backed up by > Volume Shadow copy Service, but beyond that I'm clueless. > > The other 2 partitions, System and Users, have 4 and 31 files, > respectively, in System Volume Information ending with > {3808876B-C176-4e48-B7AE-04046E6CC752} and varying in size from 30 > MB to 5.5 GB. > > Thanks for the assistance. > > |
| | #7 (permalink) |
| Guest | Re: 43 GB System File in System Volume Information on 160 GB partition They're shadow copy files themselves used for restore points and the like. Check out http://blogs.technet.com/filecab/arc...ows-vista.aspx Joe "Brent" <HarvestThis@Spammers.Net> wrote in message news:eHISqyZfHHA.928@TK2MSFTNGP02.phx.gbl... > It is a System File with NO extension. > > Your excellent suggestion about the registry search turned up: > > HKLM\SYSTEM\CurrentControlSet\Control\BackupRestore\FilesNotToBackup\VSS > Default Provider > > with a value of > > \System Volume Information\*{3808876B-C176-4e48-B7AE-04046E6CC752} /s > > Obviously SVI files ending with {3808876B-C176-4e48-B7AE-04046E6CC752} are > not to be backed up by Volume Shadow copy Service, but beyond that I'm > clueless. > > The other 2 partitions, System and Users, have 4 and 31 files, > respectively, in System Volume Information ending with > {3808876B-C176-4e48-B7AE-04046E6CC752} and varying in size from 30 MB to > 5.5 GB. > > Thanks for the assistance. > > > "Gerry Cornell" <gcjcvis@nospam.com> wrote in message > news:OJB5RfZfHHA.1456@TK2MSFTNGP04.phx.gbl... >> Brent >> >> What is the file extension? >> >> Have you searched your registry using regedit to see if the guid (if that >> is what they are?) appears in the registry to get a programme name? >> >> -- >> >> >> Hope this helps. >> >> Gerry >> ~~~~ >> FCA >> Stourport, England >> Enquire, plan and execute >> ~~~~~~~~~~~~~~~~~~~ >> >> "Brent" <HarvestThis@Spammers.Net> wrote in message >> news:%23u6vtsWfHHA.4156@TK2MSFTNGP02.phx.gbl... >>> Should have mentioned that I already tried that, to no avail. >>> >>> Thanks for responding. >>> >>> >>> "Gerry Cornell" <gcjcvis@nospam.com> wrote in message >>> news:%23Oq%23GjVfHHA.208@TK2MSFTNGP05.phx.gbl... >>>> Brent >>>> >>>> Run Disk CleanUp, More, Options, System Restore. What affect does it >>>> have on the file size? >>>> >>>> -- >>>> >>>> >>>> Hope this helps. >>>> >>>> Gerry >>>> ~~~~ >>>> FCA >>>> Stourport, England >>>> Enquire, plan and execute >>>> ~~~~~~~~~~~~~~~~~~~ >>>> >>>> >>>> "Brent" <HarvestThis@Spammers.Net> wrote in message >>>> news:%23LxvtSUfHHA.4868@TK2MSFTNGP06.phx.gbl... >>>>> (1) File name: >>>>> {ca0a01b4-d58c-11db-8afb-0013720efba8}{3808876b-c176-4e48-b7ae-04046e6cc752}. >>>>> >>>>> (2) Partition is NOT System partition. >>>>> >>>>> (3) System Restore on this partition was ENabled by default, but is >>>>> now >>>>> DISabled. >>>>> >>>>> (4) File is modified after each boot. (System log entry nearest to >>>>> Date/Time Modified is Windows Modules Installer service entering >>>>> stopped >>>>> state.) >>>>> >>>>> A single file consuming over 25% of a partition seems excessive. Any >>>>> ideas? >>>>> >>>>> TIA. >>>>> >>>>> >>>> >>> >> > |
| Get rid of System Volume Information | Vista file management | |||
| System Volume Information | Vista performance & maintenance | |||
| System Volume Information | Vista security | |||
| Need to fix System Volume Information | Vista security | |||
