Vista - svchost problem with constant hard drive accessing
Old 04-13-2007   #1 (permalink)
mikesay98
Hi everyone, I've got an interesting problem. I purchased a Vista-ready
computer in November, and received my upgrade Home Premium HP disk last
month. Suffice it to say, this problem popped up when I did the upgrade, so
I did a full clean install, and the problem still exists.
Ever since getting Vista, my computer has this problem of continually
accessing the hard drive, sometimes upwards of over 1 hour. The hard drive
will just continue to work and work and the noise doesn't stop for the whole
time. I remember before I did the full clean install, I installed I think it
was process monitor or some other program from Microsoft and I found it was
svchost.exe that seemed to be continually accessing my hard drive over and
over again.
This problem can happen randomly, or it often happens when the computer is
idle for a while. The hard drive will start accessing continuously, and
sometimes if move the mouse, it will stop, sometimes not. However, it's
always guaranteed when I start the computer up. Whether I've signed in or
not, after about 30 seconds of quiet from the computer, the hard drive will
begin to access and access for upwards of 5 minutes!
Now, I've tested the svchost.exe theory and it seems to explain it. Before
the clean install, I was able to bring up the task manager, and find an
svchost.exe process that was running that was using maybe 3-4% of the CPU and
end the process and that would fix it for a while. Problem was, after doing
that, it would revert Vista to Home basic. Eventually, home premium came
back and often did the problem as well. Now, the only way to stop it seems
to catch svchost.exe when the computer is first loading everything into
windows upon log-in. But still, it reverts to home basic.
Something interesting things to note here, though, is that (1) the CPU usage
continues to stay low during all this hard drive access. (2) This problem
has surfaced both after an upgrade and a clean install, so I can't possibly
see it as being a virus or malicious software, as that would have been
cleaned away. (3) The computer is only 5 months old, and while I did upgrade
the processor and add more RAM, those are the only changes I've done, and the
problem existed beforehand. (4) I've done Vista compatibility tests, and
even though it was advertised as Vista ready, it passes the tests just fine,
so all hardware must be compatible.
So, I'm really at a loss for what to do here. If people have suggestions,
solutions, programs to help me give you more info, I'm ALL EARS! Please,
help me! While this isn't the worst thing in the world, it can be quite
annoying to suddenly have your computer decide to be noisy for a half hour or
more, especially when you want to watch TV or something...
Thanks!
Michael
PS. I do know when defrags are scheduled, and I have run them, HD usage is
low, and it still happens. HELP!
Old 04-14-2007   #2 (permalink)
Joe Guidera
Re: svchost problem with constant hard drive accessing
svchost is a generic shell for device drivers or programs that run in tbe
background. Open up task manager and select the services tab to see what
those are. However, if you want a better idea of what's actually going on,
grab a copy of process explorer at
http://www.microsoft.com/technet/sys...sExplorer.mspx
If will show you the processes in a tree view which will allow you to see
which service running within svchost is actually doing what.
Joe
"mikesay98" <mikesay98@discussions.microsoft.com> wrote in message
news:9644EC8A-6586-4449-966A-60753C5BC550@microsoft.com...
> so
> drive
> whole
> it
> was
> over again.
> will
> Before
> and
> doing
> seems
> usage
> possibly
> upgrade
> the
> fine,
> or
> Thanks!
> Michael
> is
Constant hard drive activity causes problems General Discussion
Accessing Second Hard Drive Vista General
Constant network access - from svchost via wufdsvc ? Vista General
Vista constant hard drive activity after boot Vista General
accessing a hard drive.. Vista hardware & devices
