Vista - Difference between junction point and directory symlink?
Old 06-15-2006   #1 (permalink)
Charles F McDevitt
Is there any difference between a junction point and a directory symlink?
I can create either one, and they seem to behave exactly the same.
Vista64 clean install has screwed up directory incorrectly showing up as a junction point! Vista installation & setup
Difference in getting the current exe directory .NET General
Slow file access after removing junction point Vista performance & maintenance
Can not create symbolic link to a file - symlink to directory is O Vista General
Junction/Symlink Support in Vista PowerShell
