Vista - system restore (automatic daily restore points)
Old 04-16-2007   #1 (permalink)
alanbriggs
Hello everyone!
I recently posted to this group regarding the fact that I felt my
system was not automaticaly creating restore points on a daily basis.
I have been observing this after following some advice and reviewing
some links to info surrounding how this works.
Basically my system is not creating restore points every day or every
24 hours of PC use as it is supposed to be doing. I am quite positive
about this.
Does anyone know why this may be? I can manually create points, points
are created if i install/uninstall software and the system creates a
restore point when automaticaly backing up via scheduled back-ups etc,
alas there are no daily restore points.
Help! - alanbriggs
Old 04-16-2007   #2 (permalink)
Michael Trevelino
RE: system restore (automatic daily restore points)
"alanbriggs" wrote:
> Hello everyone!
> about this.
> Help! - alanbriggs
My Vista pc was not doing the backups either. I found that my pc was
stopping the hard drive after two hours (also dropping my internet
connection), I changed this setting and the backups are working every day.
Mike T.
Old 04-16-2007   #3 (permalink)
John Barnes
Re: system restore (automatic daily restore points)
Since March 31, I have had only 2 system restore points created and they
were approximately 30 hours apart on the 7th and 8th. The other 8 restore
points are the result of installs from Windows Update.
"alanbriggs" <alan73briggs@yahoo.co.uk> wrote in message
news:1176721450.910924.132390@y80g2000hsf.googlegroups.com...
> Hello everyone!
> about this.
> Help! - alanbriggs
Automatic System Restore Points and SP2 Vista performance & maintenance
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System restore not creating daily points Vista General
System Restore: do restore points persist after a restore? Vista General
System Restore Deleting Restore Points Automatically.... Vista General
