Vista - Mouse problem
Old 04-16-2007   #1 (permalink)
Boobay
Mouse problem
Greetings,
Did anyone have difficulty with Windows Vista Ultimate noticing your
USB mouse? I've tried two USB optical mice and the plug-n-play is not
even noticing the USB device. The USB port is functional because I've
tried each port with my jumpdrive.
Any ideas?
Thanks,
Bobby
Old 06-12-2007   #2 (permalink)
timc101
RE: Mouse problem
Boobay:
I had the same problem with my Systemax laptop. There was a reply here from
HP that said to get rid of the legacy mouse stuff in your BIOS. I think that
worked as well as uninstalling unknown devices from the control panel.
My lap top finger pointer mouse works well but the USB mouse sometimes jumps
unexplicably. I used to have complete chaos; at least now, it is somewhat
controlled chaos.
It is rather pathetic that Vista can't handle a USB mouse that well.
Hope this helps.
Tim
"Boobay" wrote:
> Greetings,
> Any ideas?
> Thanks,
> Bobby
Mouse Problem General Discussion
MOUSE PROBLEM Vista General
Mouse problem General Discussion
Mouse Problem Vista hardware & devices
Help me: mouse problem Vista General
