| | Vista Home Premium and auto starting programs hi, in Windows XP i was able to add a file to the startup folder and, when booting up, have windows run that file (it was a Lotus Organizer file). how can i do this in Vista? (Lotus Organizer is an old, old app and does not have an option to auto run at startup.) cheers pat |
| | Re: Vista Home Premium and auto starting programs Hi Pat, Place the shortcut here: C:\Users\<user>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "pat" <plongo99@hotmail.com> wrote in message news:jj6d23t0rns9qfcbd67v36v8k905hoehqe@4ax.com... > hi, > > in Windows XP i was able to add a file to the startup folder and, when > booting up, have windows run that file (it was a Lotus Organizer > file). > > how can i do this in Vista? (Lotus Organizer is an old, old app and > does not have an option to auto run at startup.) > > cheers > > pat |
| BT Auto Backup problem with 'Initialize' on Vista Home Premium | Vista General | |||
| Vista Home Premium Auto-backup: Error 80070057 | Vista performance & maintenance | |||
| Vista Home Premium - IE exit, auto-restart | Vista General | |||
| Starting Windows Vista Home Premium the very 1st time | Vista installation & setup | |||
| compatible fax programs for vista home premium | Vista print fax & scan | |||
