| | Power and Sleep Settings I purchased a computer about 2 months ago with Windows Vista Home Premium installed and all seemed OK. However I have noticed recently that the Sleep function no longer works. I have gone into Power Options to check and it is set to "Balanced", the default, with "Turn off display" to be 20 mins and "Put computer to sleep" to be 1 hour. This does not seem to be working. I know, when I first used the computer, that both of these worked but am not certain about the times. I would be greatful for any suggestions as to how I can get this function working again. Many thanks. |
| | RE: Power and Sleep Settings I have the same problem. It seems to have something to do with plugging things into the USB ports because when I remove it (more specifically a webcam), power management starts to work again. I've contacted the maker of the webcam (Logitech) but they blame vista. Basically, I don't have an answer to your problem, I need help too. Thanks. "chick" wrote: > I purchased a computer about 2 months ago with Windows Vista Home Premium > installed and all seemed OK. However I have noticed recently that the Sleep > function no longer works. I have gone into Power Options to check and it is > set to "Balanced", the default, with "Turn off display" to be 20 mins and > "Put computer to sleep" to be 1 hour. This does not seem to be working. I > know, when I first used the computer, that both of these worked but am not > certain about the times. > I would be greatful for any suggestions as to how I can get this function > working again. > Many thanks. |
| HD's going to sleep / power settings adjusted | Vista hardware & devices | |||
| Power-Off vs Sleep | Vista installation & setup | |||
| Alter (auto) Power settings when plugged in or on Battery Power? | Vista performance & maintenance | |||
| Vista power settings - power button functionality | Vista installation & setup | |||
| Sleep vs. hibernate power settings | Vista General | |||
