| | 5.1 Surround Sound When I Bought My Computer My 5.1 Surround Sound Worked Just Fine. Recently I Had To Reinstall Windows Vista Home Premium 32 Bit. My Surround Sound No Longer Worked I Updated Drivers And Now My Speakers Don't Work At All. I Can Roll Back Drivers And They Work But Only In Stereo I Have An EMachine T5224 With A Sigmatel Sound Card |
| | Re: 5.1 Surround Sound "1BadAssZ28" <1BadAssZ28@discussions.microsoft.com> wrote in message news:A8A1245D-59F9-4700-A2EE-F920A73B570F@microsoft.com... > When I Bought My Computer My 5.1 Surround Sound Worked Just Fine. > Recently I Had To Reinstall Windows Vista Home Premium 32 Bit. > My Surround Sound No Longer Worked I Updated Drivers And Now My Speakers > Don't Work At All. > I Can Roll Back Drivers And They Work But Only In Stereo > I Have An EMachine T5224 With A Sigmatel Sound Card Vista is certainly capable of 5.1 surround sound; that's what I'm using on mine. I get the idea, though, that sound drivers are (very surprisingly to me) among the most problematic drivers. My new Vista machine just has motherboard sound (but still 5.1/7.1 if desired). The builder didn't install the software for the card, so I installed it from the included CD. Wasn't Vista compatible, apparently, and the PC wouldn't start afterwards. A Restore back to the previous good start, prior to the sound drivers, fixed everything, of course. I downloaded the new Vista drivers from the manufacturer's site, and everything works fine now. 5.1/7.1 is chosen from the software on my computer, as are other options. Anyhow, not sure this will help you, as you said you tried updated drivers, but make sure the drivers are intended for Vista, then after installing, check the various programs/options that come with the drivers, to set it up properly. Good luck. -- Regards, Rick Raisley |
| windows vista ultimate 32 bit | Re: 5.1 Surround Sound hi i have also been having issues with my 5.1 sorround i originally tried using the drivers which came with my speakers and it resulted in no sound whatsoever so i uninstalled it and used the standard drivers that come with vista but i only seem to get 2 channel sound no matter what settings i change i then tried using the soundMAX software and everytime i install it i get diffferent results O.o and now it simply does the same as the standard drivers im completely out of ideas here and there is no site for the hardware ive purchased (gigatech5.1 gaming system) Gigatech Gigasound G-501 5.1 Home Theater Speaker - Sound Card and Speakers - Gigatech - Speakers - Landmark Computers if any1 could give me a hand with this issue it would be really gr8 thnx |
| 5.1 Surround Sound | Vista music pictures video | |||
| Surround sound | Vista hardware & devices | |||
| Surround Sound with wmp 11? | Vista music pictures video | |||
| 4.1 Surround Sound | Vista hardware & devices | |||
