Vista - Changing default setting for Start > Shutdown
Old 04-23-2007   #1 (permalink)
Thomas G. Madsen
I'm aware of the 'Power buttons and lid' option under 'Change
advanced power settings' but one can only choose between 'Shut
down' or 'Sleep'. I wish that the default setting is 'Restart'.
How can I achieve that?
(Vista Ultimate x64).
Regards
Madsen
Setting a default printer for the DEFAULT USER Vista print fax & scan
Changing default behaviour of Sleep to Shutdown computer... Vista General
Start -> Shutdown -> Default to Shutdown? Vista General
Default shutdown choice Vista installation & setup
Changing Start Menu Search default selection from "Search the Com. Vista file management
