Vista - How to adjust the lcd brightness?
Old 04-24-2007   #1 (permalink)
Edge30
Hello,
Some Vista systems show in the power options on the left side a slider
labeled "Adjust the LCD Brightness". But some other systems not.
Does anybody know the reason why some systems show and others don't?
thanks
e.
Old 04-24-2007   #2 (permalink)
Richard Urban
Re: How to adjust the lcd brightness?
Video driver options?
Regards,
Richard Urban
Quote from George Ankner:
If you knew as much as you think you know,
You would realize that you don't know what you thought you knew!
"Edge30" <edillere@hotmail.com> wrote in message
news:%23EVqB6qhHHA.4904@TK2MSFTNGP05.phx.gbl...
> Hello,
> thanks
> e.
Old 04-24-2007   #3 (permalink)
Ronnie Vernon MVP
This is a function of the driver, not Vista.
The standard way to adjust brightness on a stand alone monitor, use the
control buttons on the front of the monitor.
On a laptop, use the function keys. These keys are usually blue colored and
are enabled by holding down the FN key and pressing the buttons for
brightness.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
> Hello,
> thanks
> e.
where can I adjust the line in Sound & Audio
Video editing software to adjust contrast,brightness etc. Vista music pictures video
How to adjust display?? Vista General
Adjust my resolution... Vista hardware & devices
