| | BUG: Problem with Holding Power Option for Monitor sleep There appears to be a bug in Vista (I have Ultimate so can't speak for others). Under the POWER OPTIONS, no matter what PLAN you are on when you choose the Option for when to turn the Display off, no matter what setting you choose, it defaults back to 20 Mins after an hour or so. Even without a boot or anything this option (which I want to set to NEVER) always appears back as 20 mins It needs to be fixed, so does MS have a Hotfix for this?? Frenchy |
| | Re: Problem with Holding Power Option for Monitor sleep "Frenchy" <Invalid@invalid.com> wrote > There appears to be a bug in Vista (I have Ultimate so can't speak for > others). > > Under the POWER OPTIONS, no matter what PLAN you are on when you choose > the Option for when to turn the Display off, no matter what setting you > choose, it defaults back to 20 Mins after an hour or so. Even without a > boot or anything this option (which I want to set to NEVER) always appears > back as 20 mins > > It needs to be fixed, so does MS have a Hotfix for this?? Doesn't happen here for Vista Ultimate RTM retail. It's set at 1 hour, been that way and stays that way. -- Rock [MS-MVP User/Shell] |
| | Re: Problem with Holding Power Option for Monitor sleep I have 3 different timings set 1 for each power scheme, they all stick with no problems. vista ultimate 64 bit RTM. mikeyhsd@comcast.net "Frenchy" <Invalid@invalid.com> wrote in message news:Otd%232$thHHA.3412@TK2MSFTNGP02.phx.gbl... There appears to be a bug in Vista (I have Ultimate so can't speak for others). Under the POWER OPTIONS, no matter what PLAN you are on when you choose the Option for when to turn the Display off, no matter what setting you choose, it defaults back to 20 Mins after an hour or so. Even without a boot or anything this option (which I want to set to NEVER) always appears back as 20 mins It needs to be fixed, so does MS have a Hotfix for this?? Frenchy |
| | RE: BUG: Problem with Holding Power Option for Monitor sleep I have vista home premium, and the same happens to me, I set all power plans to never shut off the display but none stay. Any help would be appreciated. "Frenchy" wrote: > There appears to be a bug in Vista (I have Ultimate so can't speak for > others). > > Under the POWER OPTIONS, no matter what PLAN you are on when you choose the > Option for when to turn the Display off, no matter what setting you choose, > it defaults back to 20 Mins after an hour or so. Even without a boot or > anything this option (which I want to set to NEVER) always appears back as > 20 mins > > It needs to be fixed, so does MS have a Hotfix for this?? > > Frenchy > > |
| | Re: BUG: Problem with Holding Power Option for Monitor sleep Did you click on the Save Changes button? Mine is set to 30 minutes and it works perfectly. Also, you could create a new Custom Plan and select that as your default. Do not forget to use the Save Changes button! "Fat70Boy" <Fat70Boy@discussions.microsoft.com> wrote in message news:CDBF89FE-CE6A-4FB3-8B07-7FBC400D4331@microsoft.com... >I have vista home premium, and the same happens to me, I set all power plans > to never shut off the display but none stay. Any help would be appreciated. > > "Frenchy" wrote: > >> There appears to be a bug in Vista (I have Ultimate so can't speak for >> others). >> >> Under the POWER OPTIONS, no matter what PLAN you are on when you choose the >> Option for when to turn the Display off, no matter what setting you choose, >> it defaults back to 20 Mins after an hour or so. Even without a boot or >> anything this option (which I want to set to NEVER) always appears back as >> 20 mins >> >> It needs to be fixed, so does MS have a Hotfix for this?? >> >> Frenchy >> >> |
| | #6 (permalink) |
| | Re: BUG: Problem with Holding Power Option for Monitor sleep Even my custom plan reverts back to shut off display atfter 20 minutes. No matter what I do it does not save my plans. "Cal Bear '66" wrote: > Did you click on the Save Changes button? > > Mine is set to 30 minutes and it works perfectly. > > Also, you could create a new Custom Plan and select that as your default. > Do not forget to use the Save Changes button! > > > "Fat70Boy" <Fat70Boy@discussions.microsoft.com> wrote in message > news:CDBF89FE-CE6A-4FB3-8B07-7FBC400D4331@microsoft.com... > >I have vista home premium, and the same happens to me, I set all power plans > > to never shut off the display but none stay. Any help would be appreciated. > > > > "Frenchy" wrote: > > > >> There appears to be a bug in Vista (I have Ultimate so can't speak for > >> others). > >> > >> Under the POWER OPTIONS, no matter what PLAN you are on when you choose the > >> Option for when to turn the Display off, no matter what setting you choose, > >> it defaults back to 20 Mins after an hour or so. Even without a boot or > >> anything this option (which I want to set to NEVER) always appears back as > >> 20 mins > >> > >> It needs to be fixed, so does MS have a Hotfix for this?? > >> > >> Frenchy > >> > >> > > |
| power option problem | General Discussion | |||
| Dual Monitor Not Holding Settings with latest 180.48 NVIDIA | Graphic cards | |||
| Is holding down power sw better than pulling plug? | Vista hardware & devices | |||
| Cordless mouse will not let monitor sleep in power saver. | Vista General | |||
| Sleep option under power greyed out | Vista performance & maintenance | |||
