Vista Tutorial - System Restore problem part 1
Old 04-26-2007   #1 (permalink)
RScotti
Guest
I am having two problems with System Restore. This is one of them.
I had 48 Restore points in System Restore. I wanted to reduce them cause the Complete PC Backup thinks it is going to
use them in my backup even though it doesn't.
I changed the RP storage to 20 GB than back to 30 GB to reduce the number of RP's and had only 6 RP's left.
but this AM, I didn't have any at all.
I Couldn't figure out how those got deleted. Since I increased the RP's not decreased them?
I checked Event Viewer and it had this @ 7:25 this AM in System.
>The shadow copies of volume C: were aborted because the shadow copy storage could not grow due to a user imposed limit.
This is the problem I think?:
>Used Shadow Copy Storage space: 15.013 GB
> Allocated Shadow Copy Storage space: 17.756 GB
> Maximum Shadow Copy Storage space: 30 GB
I thought it would use the 30 GB's not the allocated.
Do I have to go back to 150 GB storage?
I put my configuration below in my signature.
I hope that helps figure out this part of my problem.
Have a good day!
Rich Scotti
My Specifications:
Vista Ultimate x86
E6700 Pentium 2.66 GHz 4M Processor
Socket LGA775 Chipset
Intel Motherboard Name975XBX2KR
Memory Installed 4GB PC6400 800 MHZ DDR2 (4 x 1 GB)
Hard driveual 500 GB SATAII 7200 rpm RAID 0 Stripe
Western Digital External USB HD 500 GB
18X DVD(+/-)R/RW (+/-)R DL drive
52X32X52/16X Combo drive
Nvidia Video Graphics GeForce 7950 GT 512 MB
500W Power supply
Sound/Audio 8 channel Integrated High Definition audio
Problem with system restore. Vista General
Problem with System Restore General Discussion
System Restore problem General Discussion
System Restore Problem Vista General
problem with system restore Vista General
