Vista - Vista Ultimate high CPU utilization problem found
Old 04-27-2007   #1 (permalink)
dyewell@gmail.com
Just figured to throw into the general knowledge base.
I just solved a high CPU utilization problem in vista ultimate for one
of my artists.
Problem: Vista Ultimate CPU is showing constant high usage that is
unattributed to any process other than system idle. Performance of the
box in After FX is consistent with a constant 40-60% overhead (not
attributed to a proc other than idle).
Solution: after review the resource monitor and task manager i saw
alot of disk thrashing and RAM use by adobe version cue. I killed the
process and disabled it. The box now runs like a normal sane machine.
hope this helps someone.
Old 04-27-2007   #2 (permalink)
xfile
Re: Vista Ultimate high CPU utilization problem found
Just FYI,
Adobe CS3 has done a good job on performance enhancement, not an
endorsement, just for information.
<dyewell@gmail.com> wrote in message
news:1177708056.771255.52440@r35g2000prh.googlegroups.com...
> of my artists.
Old 04-28-2007   #3 (permalink)
Vista Advocate - Now
"xfile" <cou-cou@remove.nospam.com> wrote in message
news:eu5qfzTiHHA.4872@TK2MSFTNGP03.phx.gbl...
> Hi,
> Just FYI,
If you can get it to install.
I tried for 3 days to get CS3 to install on 3 different machines, but no
joy.
It's gone back, and I've got my money back.
>> of my artists.
Fix to MY problem for Explorer window at High CPU utilization General Discussion
High CPU utilization by system and NDIS.SYS Vista networking & sharing
High CPU utilization with svchost.exe / dwm.exe Vista performance & maintenance
High Explorer CPU utilization Vista performance & maintenance
WMDC has high CPU utilization when connected and doing nothing Vista General
