| | Can't Start Vista, and problems with Startup Repair! Hi, I do not know what I did wrong, but one day mysteriously Vista started rebooting non-stop. This would happen even if I tried Safe Mode or Last Know Good Config. My PC suggested that I try Startup Repair from my Vista DVD, but when I tried using it, it was stuck for over an hour searching for Windows installations. To put the cherry on the top, I have BitLocker enabled right now, so I can't use any other way to forage my files elsewhere. I really don't know what to do. |
| | Re: Can't Start Vista, and problems with Startup Repair! Once you enabled bitlocker, you pretty much limited your options. Anyone using it MUST make regular backups if they have anything of value on the computer, and why use bitlocker if you don't. "IS10" <IS10@discussions.microsoft.com> wrote in message news:695FA811-9BF4-4F8E-80E8-7E0DA0122C2C@microsoft.com... > Hi, > > I do not know what I did wrong, but one day mysteriously Vista started > rebooting non-stop. This would happen even if I tried Safe Mode or Last > Know > Good Config. My PC suggested that I try Startup Repair from my Vista DVD, > but > when I tried using it, it was stuck for over an hour searching for Windows > installations. To put the cherry on the top, I have BitLocker enabled > right > now, so I can't use any other way to forage my files elsewhere. I really > don't know what to do. |
| | Re: Can't Start Vista, and problems with Startup Repair! Could be disk failure. If you have no other options, I suggest you start with a boot disk check utility like HDD regenerator to locate and mark bad sectors. This could waste of a whole night but it could save your data. "John Barnes" <jbarnes@email.net> wrote in message news:O53iL0aiHHA.4132@TK2MSFTNGP05.phx.gbl... > Once you enabled bitlocker, you pretty much limited your options. Anyone > using it MUST make regular backups if they have anything of value on the > computer, and why use bitlocker if you don't. > > > "IS10" <IS10@discussions.microsoft.com> wrote in message > news:695FA811-9BF4-4F8E-80E8-7E0DA0122C2C@microsoft.com... >> Hi, >> >> I do not know what I did wrong, but one day mysteriously Vista started >> rebooting non-stop. This would happen even if I tried Safe Mode or Last >> Know >> Good Config. My PC suggested that I try Startup Repair from my Vista DVD, >> but >> when I tried using it, it was stuck for over an hour searching for >> Windows >> installations. To put the cherry on the top, I have BitLocker enabled >> right >> now, so I can't use any other way to forage my files elsewhere. I really >> don't know what to do. > |
| | Re: Can't Start Vista, and problems with Startup Repair! Dont' tell me let me guess. the problems started when you enable bitlocker. "John Barnes" <jbarnes@email.net> wrote in message news:O53iL0aiHHA.4132@TK2MSFTNGP05.phx.gbl... > Once you enabled bitlocker, you pretty much limited your options. Anyone > using it MUST make regular backups if they have anything of value on the > computer, and why use bitlocker if you don't. > > > "IS10" <IS10@discussions.microsoft.com> wrote in message > news:695FA811-9BF4-4F8E-80E8-7E0DA0122C2C@microsoft.com... >> Hi, >> >> I do not know what I did wrong, but one day mysteriously Vista started >> rebooting non-stop. This would happen even if I tried Safe Mode or Last >> Know >> Good Config. My PC suggested that I try Startup Repair from my Vista DVD, >> but >> when I tried using it, it was stuck for over an hour searching for >> Windows >> installations. To put the cherry on the top, I have BitLocker enabled >> right >> now, so I can't use any other way to forage my files elsewhere. I really >> don't know what to do. > |
| Vista Startup Repair cannot repair this computer automatically | Vista General | |||
Vista won't start - Startup Repair can't.. what next | General Discussion | |||
| 2 different vista problems. Memory dump crash and startup repair cannot fix problems | Vista General | |||
| everytime i start my laptop it will show startup repair screen | Drivers | |||
| Startup repair problems | Vista installation & setup | |||
