Vista - Slide Show button does not do anything when I click on it
Old 04-28-2007   #1 (permalink)
Queviko
Dear all,
When I'm in a directory with some JPG photos (or others), I can't see them
as a slideshow.
Why? Simply because when I click on the "Slide Show" button in the Explorer
icons bar, nothing happen. Nothing.
It seems that the link with Photo Gallery is broken. It does not launch it.
I can of course launch Photo Gallery manually via the
WindowsPhotoGallery.exe and look for the same directory, see the photos and
start a slideshow without any problem.
So only the direct link to Photo Gallery from the Explorer "Slide Show"
icon/button does not work. Which is really a pain as it was usefull to have
the slideshow launch immediately in the current directory.
Any idea?
Thanks in advance,
Jean-Frederic
Old 04-30-2007   #2 (permalink)
Ramesh, MS-MVP
Re: Slide Show button does not do anything when I click on it
Jean,
This is usually caused by a buggy third-party shell extension. Following "Method 2" in the following article should isolate the problem:
http://windowsxp.mvps.org/slowrightclick.htm
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
Windows® Troubleshooting http://www.winhelponline.com
"Queviko" <Queviko@discussions.microsoft.com> wrote in message news:271FF6B1-785B-49F6-BE58-3897775469CD@microsoft.com...
Dear all,
as a slideshow.
Any idea?
Thanks in advance,
Jean-Frederic
Slide show? Vista General
Slide Show Button Not Working Anymore Vista General
Slide Show Vista music pictures video
Slide Show Vista installation & setup
Slide Show Vista General
