Vista - keep same column widths in all folders
Old 04-29-2007   #1 (permalink)
Catherine
How can I ensure that all folders (Windows Vista) retain the identical column
widths? Also, can this be done even when I create a new folder, so that the
new folder has the same column widths? It is time-consuming to expand /
contract the widths. I did go to the "View" tab and select "Apply to all
folders", but that didn't seem to work. Thank you.
Folders Column Disappears... Vista General
Folders Column disappears... Vista mail
Explorer Column Widths Vista file management
Column widths Explorer Vista x64 Vista General
