| | half lines display every inch on widescreen monitor with VISTA I just got a new HP PC with VISTA and every inch on the widescreen display, the line of text is cut off or displays only half the line of text (upper half). As the text scrolls on the screen it corrects, but the new line in the old place is then cut in half. Is it VISTA, a display setting, or do I have a defective MONITOR? Thanks, ~Mel |
| | RE: half lines display every inch on widescreen monitor with VISTA FYI, Found my own answer - the resolution on the MONITOR was set wrong. Paid Best Buy Geeks to set it up when I bought it. Apparently they make mistakes too. ~Back in business now ~ no more cut off lines scrolling up/down the screen. ~Mel "Mel" wrote: > I just got a new HP PC with VISTA and every inch on the widescreen display, > the line of text is cut off or displays only half the line of text (upper > half). As the text scrolls on the screen it corrects, but the new line in > the old place is then cut in half. > > Is it VISTA, a display setting, or do I have a defective MONITOR? > Thanks, ~Mel |
| Widescreen Monitor | Vista hardware & devices | |||
| [Vista widescreen monitor] - how do i stretch the movie to fit?? | Vista General | |||
| Vista Ultimate on 46 in 1080P widescreen. Display hard on eyes at | Vista General | |||
| Widescreen TV not working as second monitor | Vista General | |||
| Aero Glass and Dell Monitor UltraSharp 3007WFP 30-inch | Vista General | |||
