Vista - ACPI\PNPB02F problem with vista beta 2
Old 06-16-2006   #1 (permalink)
Amb32
my system
Operating System: Windows Vistaâ„¢ Ultimate (6.0, Build 5384)
(5384.winmain_beta2.060518-1455)
Language: English (Regional Setting: English)
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon(tm) 64 Processor 3000+
Memory: 1022MB RAM
Page File: 734MB used, 1577MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DX Setup Parameters: Not found
DxDiag Version: 6.00.5384.0004 32bit Unicode
i get the unknown device and when i click on details i get this
ACPI\PNPB02F
*PNPB02F
ive tried having it look for drivers on the motherboard disk with no luck
any help would be great
Old 06-16-2006   #2 (permalink)
Carlos
RE: ACPI\PNPB02F problem with vista beta 2
That's your Joystick Gameport.
If you also have a question mark corresponding to PNPB02F device, that's
your MIDI port.
Carlos
"Amb32" wrote:
> my system
> Memory: 1022MB RAM
> ACPI\PNPB02F
> *PNPB02F
Old 06-16-2006   #3 (permalink)
Carlos
Drivers belong to the Realtek audio chipsets in the mobo.
Realtek Web page is
http://www.realtek.com.tw/downloads/...&Software=True
Drivers are for x64 (not Vista).
I would extract the driver
(ftp://152.104.238.194/pc/ac97/alc650/WDM_A389.exe) to a folder and try to
install only the joystick/midi drivers from the \WDM folder.
Carlos
> your MIDI port.
> Carlos
> "Amb32" wrote:
> > my system
> > Memory: 1022MB RAM
> > ACPI\PNPB02F
> > *PNPB02F
Old 06-16-2006   #4 (permalink)
Amb32
will the x64 drivers be fine? i have the 32 bit vista beta 2 installed ??
> Realtek Web page is
> Carlos
> > your MIDI port.
> > Carlos
> > "Amb32" wrote:
> > > my system
> > > Memory: 1022MB RAM
> > > ACPI\PNPB02F
> > > *PNPB02F
Old 06-16-2006   #5 (permalink)
Amb32
also its basically a ? Unknown Device with the ! in it
> Realtek Web page is
> Carlos
> > your MIDI port.
> > Carlos
> > "Amb32" wrote:
> > > my system
> > > Memory: 1022MB RAM
> > > ACPI\PNPB02F
> > > *PNPB02F
Old 06-16-2006   #6 (permalink)
Colin Barnhorst
Re: ACPI\PNPB02F problem with vista beta 2
No.
"Amb32" <Amb32@discussions.microsoft.com> wrote in message
news:63551A53-7331-4C9D-9B83-012BD1B24807@microsoft.com...
>> Realtek Web page is
>> to
>> Carlos
>> > that's
>> > your MIDI port.
>> > Carlos
>> > "Amb32" wrote:
>> > > my system
>> > > Operating System: Windows VistaT Ultimate (6.0, Build 5384)
>> > > Memory: 1022MB RAM
>> > > ACPI\PNPB02F
>> > > *PNPB02F
>> > > luck
Old 06-16-2006   #7 (permalink)
Carlos
Driver package also includes 32-bit drivers.
So, my workaround might just work.
Carlos
"Colin Barnhorst" wrote:
> No.
> >> Realtek Web page is
> >> to
> >> Carlos
> >> > that's
> >> > your MIDI port.
> >> > Carlos
> >> > "Amb32" wrote:
> >> > > my system
> >> > > Memory: 1022MB RAM
> >> > > ACPI\PNPB02F
> >> > > *PNPB02F
> >> > > luck
Old 06-16-2006   #8 (permalink)
Amb32
ok tried your workaround and no go what i did is basically extracted it to a
folder went to device manager to unknown device properties and update driver
then choose the location to look myself and still no good says could not find
any drivers for the device.. any other ideas? i dont know if this changes it
or not but i do have
a gigabyte k8ns nforce 3 250..
> Carlos
> > No.
> > >> Realtek Web page is
> > >> to
> > >> Carlos
> > >> > that's
> > >> > your MIDI port.
> > >> > Carlos
> > >> > "Amb32" wrote:
> > >> > > my system
> > >> > > Memory: 1022MB RAM
> > >> > > ACPI\PNPB02F
> > >> > > *PNPB02F
> > >> > > luck
Old 06-17-2006   #9 (permalink)
Carlos
Didn't work for me either on x64.
Will have to wait for Realtek to release Vista specific drivers.
Carlos
> > Carlos
> > > No.
> > > >> Realtek Web page is
> > > >> to
> > > >> Carlos
> > > >> > that's
> > > >> > your MIDI port.
> > > >> > Carlos
> > > >> > "Amb32" wrote:
> > > >> > > my system
> > > >> > > Memory: 1022MB RAM
> > > >> > > ACPI\PNPB02F
> > > >> > > *PNPB02F
> > > >> > > luck
Old 06-23-2006   #10 (permalink)
Michael
That particular site released the driver on the 22 June...
> > Realtek Web page is
> > Carlos
> > > your MIDI port.
> > > Carlos
> > > "Amb32" wrote:
> > > > my system
> > > > Memory: 1022MB RAM
> > > > ACPI\PNPB02F
> > > > *PNPB02F
ACPI\PNPB02F Unknown device issue solution Vista hardware & devices
ACPI\PNPB02F Unknown device issue solved!!!! Vista General
ACPI\PNPB02F Unknown device Vista General
Beta 2 install failes with ACPI error Vista installation & setup
Vista Beta 2 installation failure due to non-ACPI compliant BIOS Vista installation & setup
