Vista - Shadow copies absolutely refuse to work
Old 05-01-2007   #1 (permalink)
aethorpe
Hello my question is that despite the fact i use vista ultimate(64 bit
version/administrator) at home and have system protection turned on my
computer refuses to make shadow copies. I have 52 gigs left on my 140 gig
hard drive. This makes no sense. I even have restore points up to last week.
Yet no file has a shadow copy, be it a word doc or jpeg. I even changed and
saved over files on purpose to try and get a shadow copy. Any help would be
good because i am absolutely stumped.
Old 05-01-2007   #2 (permalink)
Chad Harris
Re: Shadow copies absolutely refuse to work
Hi aethorpe--
I'd first try to solve this by running SFC. Type cmd in search box above
Start Button>rt. click cmd when pops up>run as admin>at prompt type sfc
/scannow.
One of the best sources for info on VSS is Jill Zoeller's blog where she and
her team have several good articles on it. That's here:
http://blogs.technet.com/filecab/
Either Search VSS or click on the links she has on the right pane.
Good luck,
CH
"aethorpe" <aethorpe@discussions.microsoft.com> wrote in message
news:AEC7D0D8-E203-497F-8264-D5B621EEBFD9@microsoft.com...
> week.
> and
> be
Old 05-01-2007   #3 (permalink)
Chad Harris
I should have added that if mine didn't work with adequate space and you
have a ton, and SFC didn't fix it, if you have a DVD I'd pop it in and try
to run a Startup Repair.
CH
> week.
> and
> be
Old 05-04-2007   #4 (permalink)
aethorpe
hey thanks for the info i am gonna give it a try tonight and see what happens
> CH
> > week.
> > and
> > be
shadow copies - children Virtual Server
shadow copies on vista? Vista General
Shadow Copies (Previous versions) of files do not work? Vista General
When exactly does Vista use shadow copies? Vista General
Shadow copies does not work!! Vista General
