Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Need help with pop up
Update your Vista Drivers Update Your Drivers Now!!
Closed Thread
Thread Tools Display Modes
Old 05-02-2007   #1 (permalink)
crash
Guest
I need help on a windows vista pop that keeps on coming up saying: "WINDOWS
EXPLORE HAS STOPPED WORKING". then it says "WINDOWS EXPLORE HAS STARTED
WORKING". It keeps on saying that and when the pop up is on the desktop you
can not click on anything else.
Old 05-03-2007   #2 (permalink)
Jdr
Guest
Re: Need help with pop up
"crash" <crash@discussions.microsoft.com> wrote in message
news:1D4227A4-65EF-4D4A-B55A-FC2919EE4494@microsoft.com...
> you
I had the same problem when using OneCare. After uninstalling it
this problem disappeared.
I you use the Google Tool Bar...
Problem caused by Google Toolbar
This problem was caused by Google Toolbar. This program was created by
Google Inc.. Google Inc. does not currently have a solution for the problem
that you reported.
Recommendation
A newer version of Google Toolbar is available for download that might
address this problem. Google Inc. recommends updating to the latest version
of Google Toolbar to take advantage of security and stability improvements.
Go online to the following website to update Google Toolbar:
Microsoft instruction is to do the following this however did not help
me at all.
Follow these steps to troubleshoot problems with Internet Explorer 7
We have detected that Internet Explorer 7 has experienced recurring errors
on your computer.
This problem is usually caused by one or more Internet Explorer add-ons.
Unfortunately, we are unable to determine which add-on is causing the
problem.
However, you can follow some troubleshooting steps to try to fix this
problem.
Examples of add-ons
Some examples of add-ons for web browsers include:
Extra toolbars
Animated mouse pointers
Stock tickers
Pop-up ad blockers
Troubleshooting
To try to solve this problem, follow these steps.
Start Internet Explorer with no add-ons
Close all Internet Explorer windows.
Click the Start button, click All Programs, click Accessories, click System
Tools, and then click Internet Explorer (No Add-ons).
If Internet Explorer starts and runs with all of the add-ons turned off,
then you need to determine which add-on is causing it to crash. Go to step
2.
If Internet Explorer crashes with all of the add-ons turned off, then you
need to reset Internet Explorer:
Reset Internet Explorer settings
By resetting Internet Explorer settings, you return it to the state it was
in when it was first installed on your computer. This is useful for
troubleshooting problems that might be caused by settings that were changed
after installation. When you restore Internet Explorer's default settings,
some webpages that rely on previously stored cookies, form data, passwords,
or previously installed browser add-ons might not work correctly. Resetting
Internet Explorer to its default settings does not delete your favorites,
feeds, and a few other personalized settings. The following table describes
what will happen to various settings when you reset Internet Explorer.
Settings categories
Items affected
Settings that are deleted
Browser history, temporary Internet files, cookies, form data, and stored
passwords
Typed URL information, offline webpages, menu extensions
Websites added to intranet, trusted, or restricted zones
Websites added for special cookie handling under the Privacy tab
Websites allowed to use pop-ups under Pop-up Blocker settings
Explorer most recently used list
Settings that are reset to Windows or manufacturer defaults
Home page (for information about backing up your home page tabs, see Back
up your home page or home page tabs) Back up your home page or home page
tabs
Search providers, tabbed browsing settings
Colors, languages, fonts and accessibility settings (General tab)
Security settings for all zones (Security tab)
Advanced tab settings
Privacy tab settings
Pop-up blocker, AutoComplete, Phishing Filter, and Zoom settings
Page setup, toolbar, and text size settings
Feeds settings (sync and notification, not feeds themselves)
ActiveX controls that are not on the pre-approved list (reset to opt-in
state)
Toolbars, browser helper objects, and browser extensions are disabled
Settings and items that are maintained
Favorites
Feeds
Content Advisor settings
Pre-approved ActiveX controls
Temporary Internet file (cache) path settings
Certificate information
Internet Programs (e‑mail, instant messenger, and other programs associated
with Internet use)
Internet connection, proxy, and VPN settings
Default web browser setting
Steps to reset Internet Explorer settings
Click the Start button, and then click Control Panel.
Double-click Network and Internet and then click Internet Options.
Click the Advanced tab.
Under Reset Internet Explorer settings, click Reset.
Restart Internet Explorer.
Disable all add-ons (one at a time) until you can no longer reproduce the
problem
Click Start, and then click Control Panel.
Click Network and Internet, and then click Internet Options.
Click the Programs tab, and then click Manage add-ons.
Click the name of the add-on you want to turn off, and then, under Settings,
click Disable.
Click OK.
Restart Internet Explorer. Continue using Internet Explorer the same way you
did when you received a crash report. If Internet Explorer continues to
crash after disabling this add-on, continue with step h.
Repeat steps b through g for each add-on listed. When you can no longer
reproduce the problem, the most recently disabled add-on is the cause of the
problem. Please report this add-on to us by using the survey at the bottom
of this page to help us improve our error responses.
If these troubleshooting steps do not solve the problem and you continue to
receive problem reports, please consider filling out the survey at the top
right of this page. To help us continue to investigate this error, include
the names of the add-ons that are currently enabled in Internet Explorer in
the comments area of the survey.
Old 05-03-2007   #3 (permalink)
Cal Bear '66
Guest
Go to Control Panel>Problem Reports and Solutions Check for new solutions, then
View problem history right click on the item and select View problem details
This should give you some idea of what caused the problem. Click the copy to
copy to clipboard link and post here (be sure to include the bucket number).
Closed Thread
Display Modes
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
