| | folder view problem anyone know how to fix the folder view problem? one day i'll have a folder set to Large Icons, and the next day, it will be set to Details. Sometimes vista will even sort the folder by group when i didnt ask for that to happen. help appreciated. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Hi, This has been all over the net. It seems to be a Vista issue that will be hopefully fixed one day with a Windows Update. It's always been flakey about the folder view. Even if you check the "Remember each folders settings" in the Folder Options. Some days ok, others "how did that change". From what I've seen, it seems to be resetting itself to the default Details view randomly. No known fix yet. At least it's a minor issue for now. Sorry, Shawn |
| | Re: folder view problem yeah tell me about it. its quite annoying, but I am kinda over it now. last time I tried stupid things and had to reinstall. I prefer to have everything in list mode. you'd think this issue existed during testing? On Thu, 3 May 2007 22:33:25 -0500, brink <brink.2q1i52@no-mx.forums.net> wrote: > >Hi, > >This has been all over the net. It seems to be a Vista issue that will >be hopefully fixed one day with a Windows Update. It's always been >flakey about the folder view. Even if you check the "Remember each >folders settings" in the Folder Options. Some days ok, others "how did >that change". From what I've seen, it seems to be resetting itself to >the default Details view randomly. No known fix yet. At least it's a >minor issue for now. > >Sorry, >Shawn -- cOS cossmo @at gmail . com |
| | Re: folder view problem I don't have this issue. I use the Windows classic interface. Vista Home Basic. idontknowtech <idontknowtech.2q1gr5@no-mx.forums.net> wrote in news:idontknowtech.2q1gr5@no-mx.forums.net: > > anyone know how to fix the folder view problem? one day i'll have a > folder set to Large Icons, and the next day, it will be set to Details. > Sometimes vista will even sort the folder by group when i didnt ask for > that to happen. help appreciated. > > |
| | Problem with MS wireless elite keyboard Help. I have the MS wireless desktop elite keyboard, which has some nice features. It works under Viata, except it keeps turning off the special function keys. It does it several times a day. There is a F key that locks the functions - it worked fine under XP. Any ideas? Also every once in a while my screen goes black for a second and comes back on. THANKS! John |
| | #6 (permalink) |
| | Re: Problem with MS wireless elite keyboard John L wrote: > Help. > > I have the MS wireless desktop elite keyboard, which has some nice > features. It works under Viata, except it keeps turning off the special > function keys. It does it several times a day. There is a F key that > locks the functions - it worked fine under XP. > > Any ideas? No idea about your problem, but you posted a reply to a thread titled "folder view problem", so the people who do know the solution to your problem are less likely to see it. It's best to start a new thread - then people browsing the forums will see your subject in the thread title. Messages are not identified as being in the same thread because they have the same subject. There is an ID embedded in each message, which is included in the header of replies to that message. Simply changing the subject does not create a new thread - you need to create a completely new message, rather than replying to an existing one. > > Also every once in a while my screen goes black for a second and comes > back on. > > THANKS! > > John |
| Problem with folder view | Vista General | |||
| Explorer/Folder view problem | Vista performance & maintenance | |||
| Fix for Folder View settings problem | Vista music pictures video | |||
| Fix for Folder View settings problem | PowerShell | |||
| Vista folder view problem | Vista General | |||
