| | Vista admin problem HI. I installed my old Microsoft Office XP software on my new Vista laptop. Outlook isn't working nearly as well as the trial of Outlook 2007, so I was going to uninstall the XP software through control panel and it is telling me "The System Administrator has set policies to prevent this installation" and the next pop-up box says I do not have sufficient access to perform that. But I AM the system administrator! |
| | Re: Vista admin problem "mbessom" <mbessom@discussions.microsoft.com> wrote in message news FBA1A9F-4C0E-40B8-87EA-ACE2443EDAD4@microsoft.com...> HI. I installed my old Microsoft Office XP software on my new Vista > laptop. > Outlook isn't working nearly as well as the trial of Outlook 2007, so I > was > going to uninstall the XP software through control panel and it is telling > me > "The System Administrator has set policies to prevent this installation" > and > the next pop-up box says I do not have sufficient access to perform that. > But I AM the system administrator! Outlook 2002 (XP) does not work on Vista. Outlook 2003 and up do. -- Frank Saunders, MS-MVP OE/WM http://www.fjsmjs.com |
| | Re: Vista admin problem Any old version of Office works on Vista. It's Office 2003 & 2007 that don't work on any Windows older than XP. The problem might be that you did not install and uninstall the trial version properly and you have corrupted the Microsoft Office default folder. Uninstall all versions of Office, reboot and delete the Microsoft Office folder, reboot and reinstall Office 2002. To uninstall when you get that "not administrator" message, just right click and choose "Run as administrator." "Frank Saunders, MS-MVP OE/WM" wrote: > "mbessom" <mbessom@discussions.microsoft.com> wrote in message > news FBA1A9F-4C0E-40B8-87EA-ACE2443EDAD4@microsoft.com...> > HI. I installed my old Microsoft Office XP software on my new Vista > > laptop. > > Outlook isn't working nearly as well as the trial of Outlook 2007, so I > > was > > going to uninstall the XP software through control panel and it is telling > > me > > "The System Administrator has set policies to prevent this installation" > > and > > the next pop-up box says I do not have sufficient access to perform that. > > But I AM the system administrator! > > Outlook 2002 (XP) does not work on Vista. Outlook 2003 and up do. > > -- > Frank Saunders, MS-MVP OE/WM > http://www.fjsmjs.com > > > > |
| Vista Admin Corrupt problem | General Discussion | |||
| Problem in creating multiple admin accounts - Vista Ultimate 64 bi | Vista account administration | |||
| Admin problem with vista | General Discussion | |||
| Admin access to Vista Registry Remote & locally in Admin Approval | Vista security | |||
| Vista Non-admin problem | Vista General | |||
