| Guest | Nero Installations Problems I tried to install a version of Nero 7 that I had on a CD and saw the warnings but thought it would be ok to install then just get the update. Bad move as it wouldnt work so I downloaded the latest Nero and it wouldnt install either , the on screen messages were to fast to read but I think it may have to be something to do with uninstalling a previous version. So tried to uninstall and it fails and gives an option to check online for a solution but this doesnt happen. So if the uninstaller doesnt work how can I remove this annoyance and get the latest version installed ? Honestly, Vista is starting to really give me the %^$# and maybe the solution to all my problems is to go back to XP but for now any help with removing Nero ? |
| Guest | Re: Nero Installations Problems A quick suggestion would be to use System Restore. Personally I gave up on Nero long ago. I think every time they update it there is some feature that doesn't work correctly. -- John Barnett MVP Associate Expert Windows - Shell/User Web: http://xphelpandsupport.mvps.org Web: http://vistasupport.mvps.org The information in this mail/post is supplied "as is". No warranty of any kind, either expressed or implied, is made in relation to the accuracy, reliability or content of this mail/post. The Author shall not be liable for any direct, indirect, incidental or consequential damages arising out of the use of, or inability to use, information or opinions expressed in this mail/post.. "will_s" <willsjunkremove@optusnet.com.au> wrote in message news:E5518EE4-7414-40F1-952A-CD818785F867@microsoft.com... >I tried to install a version of Nero 7 that I had on a CD and saw the >warnings but thought it would be ok to install then just get the update. >Bad move as it wouldnt work so I downloaded the latest Nero and it wouldnt >install either , the on screen messages were to fast to read but I think it >may have to be something to do with uninstalling a previous version. So >tried to uninstall and it fails and gives an option to check online for a >solution but this doesnt happen. So if the uninstaller doesnt work how can >I remove this annoyance and get the latest version installed ? > > Honestly, Vista is starting to really give me the %^$# and maybe the > solution to all my problems is to go back to XP but for now any help with > removing Nero ? > > > |
| Guest | Re: Nero Installations Problems Sometimes you forget the simple...thanks Now have Nero back on....... "John Barnett MVP" <freelanceit@mvps.org.NOSPAM> wrote in message news:%23kav3swjHHA.4628@TK2MSFTNGP06.phx.gbl... >A quick suggestion would be to use System Restore. Personally I gave up on >Nero long ago. I think every time they update it there is some feature that >doesn't work correctly. > > -- > John Barnett MVP > Associate Expert > Windows - Shell/User > > Web: http://xphelpandsupport.mvps.org > Web: http://vistasupport.mvps.org > > The information in this mail/post is supplied "as is". No warranty of any > kind, either expressed or implied, is made in relation to the accuracy, > reliability or content of this mail/post. The Author shall not be liable > for any direct, indirect, incidental or consequential damages arising out > of the use of, or inability to use, information or opinions expressed in > this mail/post.. > > "will_s" <willsjunkremove@optusnet.com.au> wrote in message > news:E5518EE4-7414-40F1-952A-CD818785F867@microsoft.com... >>I tried to install a version of Nero 7 that I had on a CD and saw the >>warnings but thought it would be ok to install then just get the update. >>Bad move as it wouldnt work so I downloaded the latest Nero and it wouldnt >>install either , the on screen messages were to fast to read but I think >>it may have to be something to do with uninstalling a previous version. So >>tried to uninstall and it fails and gives an option to check online for a >>solution but this doesnt happen. So if the uninstaller doesnt work how can >>I remove this annoyance and get the latest version installed ? >> >> Honestly, Vista is starting to really give me the %^$# and maybe the >> solution to all my problems is to go back to XP but for now any help with >> removing Nero ? >> >> >> > |
| Guest | Re: Nero Installations Problems Well at least you are now up and running again. -- John Barnett MVP Associate Expert Windows - Shell/User Web: http://xphelpandsupport.mvps.org Web: http://vistasupport.mvps.org The information in this mail/post is supplied "as is". No warranty of any kind, either expressed or implied, is made in relation to the accuracy, reliability or content of this mail/post. The Author shall not be liable for any direct, indirect, incidental or consequential damages arising out of the use of, or inability to use, information or opinions expressed in this mail/post.. "will_s" <willsjunkremove@optusnet.com.au> wrote in message news:C533694E-6054-4FB2-8CDC-3E650D66F465@microsoft.com... > Sometimes you forget the simple...thanks > > Now have Nero back on....... > > > "John Barnett MVP" <freelanceit@mvps.org.NOSPAM> wrote in message > news:%23kav3swjHHA.4628@TK2MSFTNGP06.phx.gbl... >>A quick suggestion would be to use System Restore. Personally I gave up on >>Nero long ago. I think every time they update it there is some feature >>that doesn't work correctly. >> >> -- >> John Barnett MVP >> Associate Expert >> Windows - Shell/User >> >> Web: http://xphelpandsupport.mvps.org >> Web: http://vistasupport.mvps.org >> >> The information in this mail/post is supplied "as is". No warranty of any >> kind, either expressed or implied, is made in relation to the accuracy, >> reliability or content of this mail/post. The Author shall not be liable >> for any direct, indirect, incidental or consequential damages arising out >> of the use of, or inability to use, information or opinions expressed in >> this mail/post.. >> >> "will_s" <willsjunkremove@optusnet.com.au> wrote in message >> news:E5518EE4-7414-40F1-952A-CD818785F867@microsoft.com... >>>I tried to install a version of Nero 7 that I had on a CD and saw the >>>warnings but thought it would be ok to install then just get the update. >>>Bad move as it wouldnt work so I downloaded the latest Nero and it >>>wouldnt install either , the on screen messages were to fast to read but >>>I think it may have to be something to do with uninstalling a previous >>>version. So tried to uninstall and it fails and gives an option to check >>>online for a solution but this doesnt happen. So if the uninstaller >>>doesnt work how can I remove this annoyance and get the latest version >>>installed ? >>> >>> Honestly, Vista is starting to really give me the %^$# and maybe the >>> solution to all my problems is to go back to XP but for now any help >>> with removing Nero ? >>> >>> >>> >> > |
| Nero problems in Event Viewer | Software | |||
| Nero problems? | Vista General | |||
| Problems watching DVD with Nero | Vista music pictures video | |||
| RE: Problems watching DVD with Nero | Vista music pictures video | |||
| Problems using Nero 6 and 7 | Vista General | |||
