Vista - Vista Ultimate x64 Will Not Enter Sleep Mode but will Enter Hibern
Old 05-07-2007   #1 (permalink)
reductant
Why won't it enter Sleep mode?
Old 05-07-2007   #2 (permalink)
Hi reductant,
Did you check the settings in "Power Options" to make sure "sleep after" or "Allow hybrid sleep" was on and that "hibernate after" is set for never in advanced power settings?
Old 05-07-2007   #3 (permalink)
reductant
Re: Vista Ultimate x64 Will Not Enter Sleep Mode but will Enter Hi
Hi, I'm sure it is checked. I went into the advanced power options and
enabled it. But when I tell the computer to sleep, the screen goes off but
Windows pops up at the welcome screen about 5 seconds later. It does this
both before and after I enabled hibernation. The computer will hibernate.
"brink" wrote:
> Hi reductant,
> Shawn
> brink
> "Practice makes perfect, then you reinstall"
> Vista 64 Home Premium
> 1.5 Gig DDR2 533 Mhz (PC4200) RAM
Old 05-07-2007   #4 (permalink)
I know this sounds funny, but try turning your mouse upside down (roller side up) when you put the computer to sleep. Sometimes the slightest movement of the mouse will bring it back awake. I noticed that when I put mine down to sleep and get up from the desk that sometimes it just pops back awake. Turned out I moved the mouse slightly when I got up. It finished going to sleep then poof awake.
Old 05-07-2007   #5 (permalink)
watercress_soup
Re: Vista Ultimate x64 Will Not Enter Sleep Mode but will Enter Hibern
tick one checkbox in power management of the mouse properties in device
manager so it doesnt allow to wake the computer.
steve
"brink" <brink.2q7bvi@no-mx.forums.net> wrote in message
news:brink.2q7bvi@no-mx.forums.net...
> I know this sounds funny, but try turning your mouse upside down (wheel
> Shawn
> brink
Old 05-07-2007   #6 (permalink)
Quote  Quote: Originally Posted by watercress_soup View Post
steve
Hi Steve,
Yeah, I know. I was just going to have him try & see 1st before he made any changes. I noticed this popping up quite a bit now on the net.
Thank you,
Vista Ultimate x64 won't enter sleep mode General Discussion
Cant enter sleep mode Vista performance & maintenance
VISTA64 fails to enter sleep mode Vista performance & maintenance
Unable to enter standby/sleep mode with x64 Vista Vista hardware & devices
Vista don't enter Sleep or S3 Mode Vista General
