Vista - Permissions problem?
Old 05-07-2007   #1 (permalink)
Nicholas Hall
I have just reinstalled my computer and I think I have a permissions
problem?
I have a feeling that the registry is not allowing programs write to it?
Most of my main programs are working fine, but I have problems with
others???
The problem I am having was covered by a post I did a little earlier on in
the day.
I have just reinstalled windows vista ultimate and to the greater part it
went alright.
The problem I am having though is some programs are being a pain.
The problem is that when some programs start up there is a installer
configuration that insists on running each time and every time.
The programs I am having problems with ran alright in the last install so I
do not know what is causing this problem.
The program I am having a problem with are the latest version of mindmanager
(version 6) and Microsoft expressions web.
When Mindmanager started up the installer popped up to finalize the
configurations. The happened every time. In the end I uninstalled the said
program.
Web expressions seem to be doing the same thing.
I am getting other things wrong, like certain files do not seem to register
right, IE I have installed a RAW plugin for my cannon camera so that I can
view .CR2 files in explorer. It is not working, all I get is a generic Adobe
icon. If a cursor file has a program associated with it I lose the icon.
Same with animated cursors.
I know people will reinstall windows but it is such a pain in the backside I
will muddle through at the moment.
Any help would be gratefully appreciated.
P.S When I run a program like isobuster (I have paid for the full version)
it asks me to enter my reg details to make it the full version. I do.
When I restart windows and run isobuster again it will ask again for the reg
details.
This is why I think it is a registry problem, IE the registry is not
allowing certain keys to be written to?
NIK
Old 05-09-2007   #2 (permalink)
Sasha
RE: Permissions problem?
Are you doing this as a standard user or as the administrator user?
The program may need to be run as an administrator user to get those
settings to save, then run as the standard user from then on.
> problem?
> others???
> the day.
> went alright.
> program.
> details.
> NIK
problem with Permissions- can anyone please help Vista General
Permissions Problem Vista networking & sharing
Permissions problem Vista General
Permissions problem? Vista installation & setup
permissions problem? Vista file management
