Vista Tutorial - Remote Desktop Won't connect
Old 05-07-2007   #1 (permalink)
John_Esler
Guest
I had a power failure while connected to a remote machine. Now when I try to
connect TS tells me I already have a connection to the console on the
machine. How do I kill the session?
Old 05-07-2007   #2 (permalink)
Ken Schaefer
Guest
Re: Remote Desktop Won't connect
Use you can use the Terminal Services Manager MMC Console to see open TS
sessions (and reset/kill the ones you don't want used). The TS Manager MMC
Console is part of adminpak.msi (you can download this from the Microsoft
website), or can be found on a Windows Server 2003 installation CD.
Cheers
Ken
"John_Esler" <John_Esler@discussions.microsoft.com> wrote in message
news:89D917C1-4868-4A07-B8D3-2FCDD00E88A4@microsoft.com...
>to
Old 05-08-2007   #3 (permalink)
John_Esler
Guest
Thanks Ken, but the TS manager wants to connect to a terminal server and I
don't have one running. I'm using remote desktop in Vista to connect to
another PC not a terminal server. Any other ideas? There must be a file or
reg entry that is telling the OS there is an open connection.
"Ken Schaefer" wrote:
> Hi,
> Cheers
> Ken
> >to
can't connect to remote desktop Vista General
Remote Desktop won't connect Network & Sharing
Remote Desktop does not connect. Vista General
Remote Desktop Connect Vista networking & sharing
Remote Desktop will not connect Vista General
