Vista - How do I check what is running in the background with Vista Ultimate? TIA!!!
Old 05-08-2007   #1 (permalink)
AnyWhere@USA.com
Old 05-08-2007   #2 (permalink)
Mike Brannigan
Re: How do I check what is running in the background with Vista Ultimate? TIA!!!
Right click the task bar and select Task Manager
Mike Brannigan
Old 05-08-2007   #3 (permalink)
Ronnie Vernon MVP
Please do not post the the entire message in the subject line. Many
newsreaders will truncate the long subject line and your message will not be
seen.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
<AnyWhere@USA.com> wrote in message
news:6uu14352n7bphs4mog1h14gnkg7pikfqme@4ax.com...
Old 05-09-2007   #4 (permalink)
Lang Murphy
Try this: http://www.whatsrunning.net/whatsrunning/main.aspx
Lang
Old 05-09-2007   #5 (permalink)
linuxcrazyman
RE: How do I check what is running in the background with Vista Ultima
If you mean what services are running in the background, open the start menu,
then right-click my computer. Select manage. Expand services and
applications, then click services. Anything that says started is running in
the background. To configure what stuff you want running in the background,
right click any of the services and selct properties. To configure which of
these you want started at startup, press <Windows Key> <r> and type
"msconfig". Then go to startup items and services.
Old 05-09-2007   #6 (permalink)
Blue Angel
Thanks for the info and sorry for the long subject.
TomP
Vista 64: Please help me get rid of mobsync.exe and wmplayer.exe always running in the background Vista General
Vista 64: Please help me get rid of mobsync.exe and wmplayer.exe always running in the background Vista networking & sharing
Vista 64: Please help me get rid of mobsync.exe and wmplayer.exe always running in the background Vista performance & maintenance
How to check if the computer is running a retail Vista? Vista General
so many DfrgNtfs.exe running background once kick off the defragment in vista Vista General
