| | Will not acknowledge Bit Defender I have Vista ultimate and am using Bit Defender Internet Security ver. 10 which is supposed to be vista compatible. I cannot get Vista to recognize it. It keeps saying I do not have a firewall or anti virus installed. |
| | Re: Will not acknowledge Bit Defender OceanLover wrote: > I have Vista ultimate and am using Bit Defender Internet Security ver. 10 > which is supposed to be vista compatible. I cannot get Vista to recognize > it. It keeps saying I do not have a firewall or anti virus installed. If you're sure that Bit Defender is compatible with Vista, you can change Security Center's settings to say that you will monitor the av yourself. Or ask Bit Defender's tech support if they know about this issue with Vista. They may have a workaround or update in the works. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: Will not acknowledge Bit Defender Thank you. After the last bit defender update vista acknowledged the program. "Malke" wrote: > OceanLover wrote: > > I have Vista ultimate and am using Bit Defender Internet Security ver. 10 > > which is supposed to be vista compatible. I cannot get Vista to recognize > > it. It keeps saying I do not have a firewall or anti virus installed. > > If you're sure that Bit Defender is compatible with Vista, you can > change Security Center's settings to say that you will monitor the av > yourself. Or ask Bit Defender's tech support if they know about this > issue with Vista. They may have a workaround or update in the works. > > > Malke > -- > Elephant Boy Computers > www.elephantboycomputers.com > "Don't Panic!" > MS-MVP Windows - Shell/User > |
| | Re: Will not acknowledge Bit Defender OceanLover wrote: > Thank you. After the last bit defender update vista acknowledged the program. > > "Malke" wrote: > >> OceanLover wrote: >>> I have Vista ultimate and am using Bit Defender Internet Security ver. 10 >>> which is supposed to be vista compatible. I cannot get Vista to recognize >>> it. It keeps saying I do not have a firewall or anti virus installed. >> If you're sure that Bit Defender is compatible with Vista, you can >> change Security Center's settings to say that you will monitor the av >> yourself. Or ask Bit Defender's tech support if they know about this >> issue with Vista. They may have a workaround or update in the works. Glad to hear you got it sorted. Thanks for taking the time to post the solution. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| Vista won't acknowledge the existence of SD-Cards | Vista hardware & devices | |||
| defender | Vista hardware & devices | |||
| Defender | Vista installation & setup | |||
| VISTA forgets 1394 Acknowledge Code | Vista hardware & devices | |||
| Error in Windows Vista Defender cant change anything in Defender! | Vista security | |||
