Vista Tutorial - Weirdest problems.Can't start programs from start menu and use Cop
Old 05-11-2007   #1 (permalink)
Mihai
Guest
Hi all,
I have the weirdest problem with my newly installed Windows Vista. Let's say
i have started a program before by going in Start -> All programs. Then the
icon will be in the start menu. If i try to click on that icon the software
doesn not start. Only if i go thru Start -> All programs.
A simmiliar problem is if i want to go into Device Manager. I usually use
Windows button + Pause/Break then press Device Manager. This doesn't work
anymore. If i go thru control panel it works fine.....again very weird.
Another problem i have is with Copy/ Paste. I insert a cd and want to copy
some files from that. Copy is avaialble in the menu but when i want to paste
the paste is grey in context menu and in manin menu on windows explorer. not
even the shortcut Ctrl + V works.
I have tried many windows but i never encountered anything close to this....
Any body has a idea what couses this ?
Best Regards
Mihai Marinescu
Old 05-12-2007   #2 (permalink)
Ramesh, MS-MVP
Guest
Re: Weirdest problems.Can't start programs from start menu and use Cop
Hi Mihai,
This sounds like a third-party shell extensions problem. Follow "Method 2" in this article.
http://windowsxp.mvps.org/slowrightclick.htm
(Ignore the title)
Note that you can undo the action any time you want. Does not cause any harm in trying the method above.
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
Windows® Troubleshooting http://www.winhelponline.com
"Mihai" <Mihai@discussions.microsoft.com> wrote in message news:04635F44-E67C-41ED-AC24-1AAA2B6AFE22@microsoft.com...
Hi all,
Best Regards
Mihai Marinescu
All programs gone from Start Menu Vista General
All Programs in Start Menu Vista General
Cannot start programs from the start menu Vista General
Can't start certain programs from Start Menu Vista General
Default Start Menu option missing from Taskbar & Start Menu properties screen Vista General
