| | remote desktop control from XP Pro to Vista (64-bit) I am trying to connect from an XP Pro desktop (at home) to a Vista (64-bit) workstation (office). In the office, I can connect to the Vista workstation from another XP Pro machine. At home, I have a home network and I have enabled port forwarding on 3389. I get the error message "This computer can't connect to the remote computer." |
| | Re: remote desktop control from XP Pro to Vista (64-bit) Hi, When you say you have enabled "port forwarding", did you do that at home? or at the office? (you need to do it at the office) Otherwise, it should just be a matter of name/IP resolution. Cheers Ken "ihhann" <ihhann@discussions.microsoft.com> wrote in message news:17626300-7EF3-476C-8748-A4128170C197@microsoft.com... >I am trying to connect from an XP Pro desktop (at home) to a Vista (64-bit) > workstation (office). In the office, I can connect to the Vista > workstation > from another XP Pro machine. At home, I have a home network and I have > enabled port forwarding on 3389. I get the error message "This computer > can't connect to the remote computer." |
| | Re: remote desktop control from XP Pro to Vista (64-bit) "ihhann" <ihhann@discussions.microsoft.com> wrote in message news:17626300-7EF3-476C-8748-A4128170C197@microsoft.com... >I am trying to connect from an XP Pro desktop (at home) to a Vista (64-bit) > workstation (office). In the office, I can connect to the Vista > workstation > from another XP Pro machine. At home, I have a home network and I have > enabled port forwarding on 3389. I get the error message "This computer > can't connect to the remote computer." It's the firewall at the office that needs port 3389 forwarded to your LAN IP/machine on the company's LAN and not port forwarding of the port on your end at the router or whatever you're using as the gateway device, since it's your machine that's initiating the contact. If the FW and security admin has any sense, and most do, they are not going to allow you to do this, since your home network and the machines on your LAN would be a security risk to the company's network. I suggest you close port 3389, because your machine is the client and the machine at work in the host that needs port 3389 forwarded. |
| | Re: remote desktop control from XP Pro to Vista (64-bit) Thanks for the prompt answers. I closed the port at the home network and I will try to open it at the office. One question though: I can connect to my Windows XP Pro desktop in the office from home (XP Pro to XP Pro) without any port forwarding. Is it different for Vista? Thanks, IHH "Mr. Arnold" wrote: > > "ihhann" <ihhann@discussions.microsoft.com> wrote in message > news:17626300-7EF3-476C-8748-A4128170C197@microsoft.com... > >I am trying to connect from an XP Pro desktop (at home) to a Vista (64-bit) > > workstation (office). In the office, I can connect to the Vista > > workstation > > from another XP Pro machine. At home, I have a home network and I have > > enabled port forwarding on 3389. I get the error message "This computer > > can't connect to the remote computer." > > It's the firewall at the office that needs port 3389 forwarded to your LAN > IP/machine on the company's LAN and not port forwarding of the port on your > end at the router or whatever you're using as the gateway device, since it's > your machine that's initiating the contact. > > If the FW and security admin has any sense, and most do, they are not going > to allow you to do this, since your home network and the machines on your > LAN would be a security risk to the company's network. > > I suggest you close port 3389, because your machine is the client and the > machine at work in the host that needs port 3389 forwarded. > |
| | Re: remote desktop control from XP Pro to Vista (64-bit) "ihhann" <ihhann@discussions.microsoft.com> wrote in message news:EA7C830A-D999-4AAA-A3CC-7200C9A7077F@microsoft.com... > Thanks for the prompt answers. > > I closed the port at the home network and I will try to open it at the > office. One question though: I can connect to my Windows XP Pro desktop > in > the office from home (XP Pro to XP Pro) without any port forwarding. Is > it > different for Vista? > First, you need to understand what port forwarding is for a NAT router, firewall appliance or an Internet software firewall solution on a gateway computer and I am not talking about some personal FW either. http://www.homenethelp.com/web/expla...arding-dmz.asp Your company's LAN network is setting behind a firewall solution, so nothing needs to be forwarded to the LAN from the Internet. Unless there is a personal FW active on the machines on the LAN, the machines can communicate with each other on the LAN on any port, because no traffic on ports on the machine are being blocked, no firewall. If a PFW is active on a machine and a inbound port like 3389 needs to be open for RDS to work at the host computer that is listening on port 3389, then a rule must be set to allow the inbound traffic on the port. No port on 3389 needs to be opened for the client machine with a personal FW, because the client machine is the one that's initiating traffic on port 3389 with the host machine Any traffic on inbound ports coming back from the host, the PFW on the client is going to open the ports to the traffic. Where the client machine has imitated the contact with a host/server/application on a host machine with a FW in play and the host/server sends traffic back to the client, that's called a solicitation for traffic by the client. All solicited traffic will be let through the FW and all unsolicited inbound traffic is blocked by the client's FW. In the case of a host/server application running on a machine with a PFW in play, the host is not the machine that's initiating contact with the client, therefore, any inbound traffic coming to the host is going to be blocked by the PFW. The inbound traffic will be blocked by the PFW at the host machine, unless a FW rule is set to open a port or ports on the FW to unsolicited inbound traffic. Solicited inbound traffic is let through and unsolicited inbound traffic is blocked, unless a rule has been set on the FW to allow unsolicited inbound traffic through the FW. That's how a PFW, NAT router, firewall appliance or software FW running on a computer works. I think you can understand why those machine on your company LAN are communicating with each other, which will be the same for a Vista machine. Vista is just another NT based O/S, like Win NT'x, Win 2k, Win XP and Win 2k3 are NT based O/S(s). It's not that gid of a deal. |
| | #6 (permalink) |
| | Re: remote desktop control from XP Pro to Vista (64-bit) There is a particular option in the Remote Desktop settings on the host computer that might need to be fixed. Open [ Control Panel > System > Remote settings ] and look for the Remote Desktop box. Make sure that, on the host computer, the radio button is filled next to "Allow connections from computers running any version of Remote Desktop (less secure)". I think XP uses a different version of RDC software than Vista, which might be the problem. If that's not it, then I don't know what else to suggest. Good luck! "ihhann" <ihhann@discussions.microsoft.com> wrote in message news:EA7C830A-D999-4AAA-A3CC-7200C9A7077F@microsoft.com... > Thanks for the prompt answers. > > I closed the port at the home network and I will try to open it at the > office. One question though: I can connect to my Windows XP Pro desktop > in > the office from home (XP Pro to XP Pro) without any port forwarding. Is > it > different for Vista? > > Thanks, IHH > > "Mr. Arnold" wrote: > >> >> "ihhann" <ihhann@discussions.microsoft.com> wrote in message >> news:17626300-7EF3-476C-8748-A4128170C197@microsoft.com... >> >I am trying to connect from an XP Pro desktop (at home) to a Vista >> >(64-bit) >> > workstation (office). In the office, I can connect to the Vista >> > workstation >> > from another XP Pro machine. At home, I have a home network and I have >> > enabled port forwarding on 3389. I get the error message "This >> > computer >> > can't connect to the remote computer." >> >> It's the firewall at the office that needs port 3389 forwarded to your >> LAN >> IP/machine on the company's LAN and not port forwarding of the port on >> your >> end at the router or whatever you're using as the gateway device, since >> it's >> your machine that's initiating the contact. >> >> If the FW and security admin has any sense, and most do, they are not >> going >> to allow you to do this, since your home network and the machines on >> your >> LAN would be a security risk to the company's network. >> >> I suggest you close port 3389, because your machine is the client and the >> machine at work in the host that needs port 3389 forwarded. >> |
| using XP remote desktop to control a Vista Home machine? | Vista networking & sharing | |||
| login control off - password required after Remote Desktop session | Vista security | |||
| Remote Control on Vista/XP | Vista General | |||
| Remote Desktop Active X Control with Vista | Vista General | |||
| Remote Desktop - XP Home taking control of Vista Home Premium | Vista General | |||
