| | Problem booting up I'm trying to fix a problem on a new (about 6 weeks old) gateway computer running vista home. When I first start up the computer nothing works. Well, I should say nothing but explorer (both internet and Windows). After 30 minutes to an hour, I am finally able to start running programs. Before that, anything I try to run gets to a splash screen and then freezes. I think I've narrowed the problem down to McAfee Security Center as that is the last thing that finally loads before stuff starts working. I'd rather not uninstall it yet (as this isn't my computer...I'm helping a friend), but was wondering if anybody else here had seen a problem like this and knew of a solution. To the best of my knowledge the computer is fully updated. Thanks for any help. |
| | RE: Problem booting up Upon further testing I don't think it is McAfee that is causing the problem. I've disabled all services and programs in the startup related to it and the problem still occurs. "Matthew Zimmer" wrote: > I'm trying to fix a problem on a new (about 6 weeks old) gateway computer > running vista home. When I first start up the computer nothing works. Well, > I should say nothing but explorer (both internet and Windows). After 30 > minutes to an hour, I am finally able to start running programs. Before > that, anything I try to run gets to a splash screen and then freezes. I > think I've narrowed the problem down to McAfee Security Center as that is the > last thing that finally loads before stuff starts working. I'd rather not > uninstall it yet (as this isn't my computer...I'm helping a friend), but was > wondering if anybody else here had seen a problem like this and knew of a > solution. To the best of my knowledge the computer is fully updated. > Thanks for any help. |
| | RE: Problem booting up Problem solved. It turned out that the shared printers were hanging and causing the large delay. I removed printer sharing from them and the computer booted right up. Not sure why the sharing was an issue, but I'm not going to worry about it at this time. "Matthew Zimmer" wrote: > Upon further testing I don't think it is McAfee that is causing the problem. > I've disabled all services and programs in the startup related to it and the > problem still occurs. > > "Matthew Zimmer" wrote: > > > I'm trying to fix a problem on a new (about 6 weeks old) gateway computer > > running vista home. When I first start up the computer nothing works. Well, > > I should say nothing but explorer (both internet and Windows). After 30 > > minutes to an hour, I am finally able to start running programs. Before > > that, anything I try to run gets to a splash screen and then freezes. I > > think I've narrowed the problem down to McAfee Security Center as that is the > > last thing that finally loads before stuff starts working. I'd rather not > > uninstall it yet (as this isn't my computer...I'm helping a friend), but was > > wondering if anybody else here had seen a problem like this and knew of a > > solution. To the best of my knowledge the computer is fully updated. > > Thanks for any help. |
| Booting up problem | General Discussion | |||
| booting problem | Vista performance & maintenance | |||
| Booting problem | Vista performance & maintenance | |||
| booting problem | Vista General | |||
| Booting problem | Vista General | |||
