Vista - high cpu usage using wmi
Old 05-13-2007   #1 (permalink)
anonymous
I have written an application that starts a ManagementEven****cher and uses
WMI. The application takes around 0-1% CPU in XP whereas in Vista CPU usage
is 40% continuously. Is there a fix?
Old 05-13-2007   #2 (permalink)
Geo
RE: high cpu usage using wmi
You are posting from the future, please adjust your time&date settings.
I never read posts from people who try to get on top of the list this way.
Old 05-13-2007   #3 (permalink)
anonymous
Re: high cpu usage using wmi
I didnt know that posts written here take around 5 minutes to appear.
anyways can you answer my question?
"Geo" <Geo@discussions.microsoft.com> wrote in message
news:E5F5B503-BB8F-4D1C-91ED-5936EC893A49@microsoft.com...
>> uses
>> usage
Old 05-13-2007   #4 (permalink)
Mr. Arnold
"anonymous" <na@vista> wrote in message
news:BDC17BA5-9403-4683-86F6-A01AC9FC2CE5@microsoft.com...
Well, your .Net program runs on a thread. So, set the thread's processing
priority.
System.Threading.Thread.CurrentThread.Priority = High, Normal,
BelowNormal -- enums.
You can look it up use the .NET IDE Help or use Google.
You should post to a MS-Public-dotnet NG.
Old 05-13-2007   #5 (permalink)
anonymous
Hi Mr Arnold, the program runs fine on Windows XP. I saw that the CPU is
used by wmiprvse.exe which is not the same process as the program. So
System.Threading.Thread.CurrentThread.Priority on the program will not
affect wmiprvse's priority. I have manually set wmiprvse.exe's priority to
low but no luck, the same 40-50% use.
This problem doesn't occur in XP, and the program and wmiprvse.exe both take
less than 1% CPU on the average. So, it is a Vista issue.
Your further suggestions are appreciated.
Thanks.
"Mr. Arnold" <MR. Arnold@Arnold.com> wrote in message
news:OQxBggUlHHA.1532@TK2MSFTNGP03.phx.gbl...
>>uses WMI. The application takes around 0-1% CPU in XP whereas in Vista CPU
>>usage is 40% continuously. Is there a fix?
> priority.
Old 05-13-2007   #6 (permalink)
Mr. Arnold
news:5DB68B6E-309C-48AD-A270-F94A06BD132D@microsoft.com...
> take less than 1% CPU on the average. So, it is a Vista issue.
You may be able to look at the code for this solution and pillage and
plunder something together that you could use, non UI. It's a shot.
http://www.codeproject.com/csharp/CustomTaskManager.asp
>>>CPU usage is 40% continuously. Is there a fix?
>> priority.
Old 05-22-2007   #7 (permalink)
bigjimmer
CURIOUS IF YOU FOUND AN ANSWER TO THIS PROBLEM?
High CPU Usage Vista General
high cpu usage when using wmi Vista performance & maintenance
High CPU usage when using WMI Vista performance & maintenance
High CPU usage Vista performance & maintenance
Very High CPU Usage Vista General
