Vista - Streets and Trips 2007 Install Problem
Old 05-14-2007   #1 (permalink)
Mel
Help!
I have installed the program with no problems, but when i try to open i get
a message box come up that tells me " your registry settings for the
application were not copied correctly to correct these settings run Setup
again for the application from the location were you originally installed
it". I ran the setup again to correct the errors but again i still get the
same message! Can anyone help??
Thank You all very much
Mel
Old 05-14-2007   #2 (permalink)
Jon
Re: Streets and Trips 2007 Install Problem
"Mel" <Mel@discussions.microsoft.com> wrote in message
news:74C49347-D0E0-4794-B3E0-7D057897D3FA@microsoft.com...
> Help!
> get
> Mel
Try running both the setup program and the program itself 'elevated' (ie
the 'Run as administrator' option)
Jon
Old 06-09-2007   #3 (permalink)
sherrye123
> > Help!
> > get
> > Mel
> Jon
Old 06-09-2007   #4 (permalink)
sherrye123
I had the same problem but when I tried to run S & T in admin mode, I found I
also had to locate the .exe file (streets.exe). None of the icons in the
start menu were pointing to the right place. Once I located the actual .exe
file, I ran that in Administrator mode and it worked! Thanks!
> > Help!
> > get
> > Mel
> Jon
Streets&Trips 2007 with GPS Nav install issue for Vista solved Vista installation & setup
streets and trips 2007 Vista General
MS Streets and Trips 2007 install problem Vista General
Microsoft Streets & Trips 2007 With GPS Locator Helps Consumers Take the Tension out of Travel Vista News
