| | Need Help Reformatting Hard Drive Hi, I have a Dell XPS1710 that I want to reformat the hard drive on. I'm not interested in using System Restore and I'm not interested in restoring back to factory condition. How can I completely reformat and reinstall using the DVD that came with my system? Running Vista Ultimate. Thanks in advance for your help. |
| | Re: Need Help Reformatting Hard Drive I might be wrong but I think that all you need to do is just boot to the install DVD and then follow the prompts. It will probably give you the option to wipe the partition and start from scratch. If not then you could just boot the computer from a bootable system disk (3.5 floppy) or a bootable system CD and run fdisk and format from there. This is assuming that you already have a good backup. ![]() Good luck. "Jimbo" <Jimbo@discussions.microsoft.com> wrote in message news:29A2E9F7-2A5C-487A-8355-FDAC7B4B0B02@microsoft.com... > Hi, > > I have a Dell XPS1710 that I want to reformat the hard drive on. I'm not > interested in using System Restore and I'm not interested in restoring > back > to factory condition. How can I completely reformat and reinstall using > the > DVD that came with my system? Running Vista Ultimate. > > Thanks in advance for your help. |
| Reformatting hard drive | Vista General | |||
| need help reformatting old hard drive | General Discussion | |||
| Crashed hard drive...copied hard drive but can't access User area | Vista General | |||
| Transferring files from Slave XP hard drive to new Vista Hard drive - primary | Vista installation & setup | |||
| Reformatting hard drive....Password won't work | Vista installation & setup | |||
