| | Programs wont load I have had my new Dell pc with vista premium for about a month now but can you tell me why, if you are using and application(word etc or checking your Antivirus) you then decide to open another program and nothing happens. The other selected program will not load until I reboot.This also applies to Autoplay. I have ticked the right boxes but a lot of the time a CD will not open |
| | Re: Programs wont load Was there ever a time when it was working properly? If so, use System Restore to go back to that period in time. If that fixes it, try to remember what applications you installed along the way...one of them may be the culprit. Or try disabling some or all of the applications that load automatically...like your anti-virus or anti-malware application (use "msconfig") and see if that makes a difference. If it worked that way out of the box then your PC is defective...call Dell tech support and ask to return it for a new one (good luck with that). Come to think of it, rather than subject yourself to tech support right away, first use the recovery disks that came with it and do a clean re-install of Vista. Tim "Pixie" <Pixie@discussions.microsoft.com> wrote in message news:409E3F97-9357-4123-B564-DBF835D1FB97@microsoft.com... >I have had my new Dell pc with vista premium for about a month now but can > you tell me why, if you are using and application(word etc or checking > your > Antivirus) you then decide to open another program and nothing happens. > The > other selected program will not load until I reboot.This also applies to > Autoplay. I have ticked the right boxes but a lot of the time a CD will > not > open |
| Web Slices wont load | Browsers & Mail | |||
| Vista wont load | Vista installation & setup | |||
| MS Office programs wont load from "Start Menu" | Vista General | |||
| os wont load and start | Vista General | |||
| Vista wont load any programs from XP | Vista performance & maintenance | |||
