| | Vista Remote Desktop disables monitor power saving. Hello All, I can connect fine to my office Vista machine (via Remote Desktop) from my XP box at home. However whenever I get back into the office the monitor on the Vista machine is on. Clearly the power saving and/or screensaver has been disabled by the remote desktop connection. This is certainly not "green", and eventually may give me some burn in problems on the monitor (OK, that may take too long to worry about). Is there a setting I've missed somewhere? Cheers, John. |
| | Re: Vista Remote Desktop disables monitor power saving. Hi John, Vista should revert to default power settings when you log on remotely as when you do it goes to the logon screen locally. When you logoff it should remain at the local logon screen. If power settings for the system are set to shut down the monitor or go to a screensaver then these should kick in. Something may be interfering with this process, but can be difficult to discern. If you are concerned with this, you may want to simply turn the monitor off when you leave the office. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "JohnD" <johnd@dyalog.com> wrote in message news:ePlbAgTmHHA.3588@TK2MSFTNGP02.phx.gbl... > Hello All, > > I can connect fine to my office Vista machine (via Remote Desktop) from my > XP box at home. However whenever I get back into the office the monitor on > the Vista machine is on. Clearly the power saving and/or screensaver has > been disabled by the remote desktop connection. > > This is certainly not "green", and eventually may give me some burn in > problems on the monitor (OK, that may take too long to worry about). > > Is there a setting I've missed somewhere? > > Cheers, > > John. |
| | Re: Vista Remote Desktop disables monitor power saving. OK Rick, Not ideal, but it's "greener" that way too. I do have "shut down monitor after 10 minutes" set, but when I come in it is on and displaying the local login screen. But, if as you say, it's "difficult to discern" why its failing I'll go with the power switch. I'd guess that its a bug in Vista somewhere though (or perhaps in the video drivers). /john "Rick Rogers" <rick@mvps.org> wrote in message news:eprG2lTmHHA.3888@TK2MSFTNGP03.phx.gbl... > Hi John, > > Vista should revert to default power settings when you log on remotely as > when you do it goes to the logon screen locally. When you logoff it should > remain at the local logon screen. If power settings for the system are set > to shut down the monitor or go to a screensaver then these should kick in. > Something may be interfering with this process, but can be difficult to > discern. If you are concerned with this, you may want to simply turn the > monitor off when you leave the office. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "JohnD" <johnd@dyalog.com> wrote in message > news:ePlbAgTmHHA.3588@TK2MSFTNGP02.phx.gbl... >> Hello All, >> >> I can connect fine to my office Vista machine (via Remote Desktop) from >> my XP box at home. However whenever I get back into the office the >> monitor on the Vista machine is on. Clearly the power saving and/or >> screensaver has been disabled by the remote desktop connection. >> >> This is certainly not "green", and eventually may give me some burn in >> problems on the monitor (OK, that may take too long to worry about). >> >> Is there a setting I've missed somewhere? >> >> Cheers, >> >> John. > |
| | Re: Vista Remote Desktop disables monitor power saving. Hello.. the problem existed in XP and now perhaps its still in Vista Here is a registry edit that enables the power off for XP when in the welcome screen mode after someone logs in remotely. I have not tested it yet with vista.. but you may want to try it after you make a restore point of course: copy the exact text into a notepad file and rename the file to have a .reg extension, then double click it to enter it into the registry.... As I said, I didn't have the chance to test it on vista yet.. so if you try it please tell us if this resolved your problem. Copy paste the below code: ------- Windows Registry Editor Version 5.00 [HKEY_USERS\.DEFAULT\Control Panel\Desktop] "PowerOffActive"="1" "ScreenSaveActive"="1" "SCRNSAVE.EXE"="(None)" "JohnD" <johnd@dyalog.com> wrote in message news:uM8dUvTmHHA.1776@TK2MSFTNGP05.phx.gbl... > OK Rick, > > Not ideal, but it's "greener" that way too. > > I do have "shut down monitor after 10 minutes" set, but when I come in it > is on and displaying the local login screen. But, if as you say, it's > "difficult to discern" why its failing I'll go with the power switch. I'd > guess that its a bug in Vista somewhere though (or perhaps in the video > drivers). > > /john > > > "Rick Rogers" <rick@mvps.org> wrote in message > news:eprG2lTmHHA.3888@TK2MSFTNGP03.phx.gbl... >> Hi John, >> >> Vista should revert to default power settings when you log on remotely as >> when you do it goes to the logon screen locally. When you logoff it >> should remain at the local logon screen. If power settings for the system >> are set to shut down the monitor or go to a screensaver then these should >> kick in. Something may be interfering with this process, but can be >> difficult to discern. If you are concerned with this, you may want to >> simply turn the monitor off when you leave the office. >> >> -- >> Best of Luck, >> >> Rick Rogers, aka "Nutcase" - Microsoft MVP >> http://mvp.support.microsoft.com/ >> Windows help - www.rickrogers.org >> My thoughts http://rick-mvp.blogspot.com >> >> "JohnD" <johnd@dyalog.com> wrote in message >> news:ePlbAgTmHHA.3588@TK2MSFTNGP02.phx.gbl... >>> Hello All, >>> >>> I can connect fine to my office Vista machine (via Remote Desktop) from >>> my XP box at home. However whenever I get back into the office the >>> monitor on the Vista machine is on. Clearly the power saving and/or >>> screensaver has been disabled by the remote desktop connection. >>> >>> This is certainly not "green", and eventually may give me some burn in >>> problems on the monitor (OK, that may take too long to worry about). >>> >>> Is there a setting I've missed somewhere? >>> >>> Cheers, >>> >>> John. >> > |
| | Re: Vista Remote Desktop disables monitor power saving. Hi Tiberius, Nope, I tried that ,and it's made not difference whatsoever. /john "Tiberius" <James@tiberius.kirk> wrote in message news:uQRSP9TmHHA.3588@TK2MSFTNGP02.phx.gbl... > Hello.. > > the problem existed in XP and now perhaps its still in Vista > > Here is a registry edit that enables the power off for XP when in the > welcome screen mode > after someone logs in remotely. I have not tested it yet with vista.. but > you may want to try it > after you make a restore point of course: > > copy the exact text into a notepad file and rename the file to have a .reg > extension, > then double click it to enter it into the registry.... > > As I said, I didn't have the chance to test it on vista yet.. so if you > try it please tell us if this resolved your problem. > > Copy paste the below code: > ------- > > Windows Registry Editor Version 5.00 > > [HKEY_USERS\.DEFAULT\Control Panel\Desktop] > "PowerOffActive"="1" > "ScreenSaveActive"="1" > "SCRNSAVE.EXE"="(None)" > > > > > > > "JohnD" <johnd@dyalog.com> wrote in message > news:uM8dUvTmHHA.1776@TK2MSFTNGP05.phx.gbl... >> OK Rick, >> >> Not ideal, but it's "greener" that way too. >> >> I do have "shut down monitor after 10 minutes" set, but when I come in it >> is on and displaying the local login screen. But, if as you say, it's >> "difficult to discern" why its failing I'll go with the power switch. I'd >> guess that its a bug in Vista somewhere though (or perhaps in the video >> drivers). >> >> /john >> >> >> "Rick Rogers" <rick@mvps.org> wrote in message >> news:eprG2lTmHHA.3888@TK2MSFTNGP03.phx.gbl... >>> Hi John, >>> >>> Vista should revert to default power settings when you log on remotely >>> as when you do it goes to the logon screen locally. When you logoff it >>> should remain at the local logon screen. If power settings for the >>> system are set to shut down the monitor or go to a screensaver then >>> these should kick in. Something may be interfering with this process, >>> but can be difficult to discern. If you are concerned with this, you may >>> want to simply turn the monitor off when you leave the office. >>> >>> -- >>> Best of Luck, >>> >>> Rick Rogers, aka "Nutcase" - Microsoft MVP >>> http://mvp.support.microsoft.com/ >>> Windows help - www.rickrogers.org >>> My thoughts http://rick-mvp.blogspot.com >>> >>> "JohnD" <johnd@dyalog.com> wrote in message >>> news:ePlbAgTmHHA.3588@TK2MSFTNGP02.phx.gbl... >>>> Hello All, >>>> >>>> I can connect fine to my office Vista machine (via Remote Desktop) from >>>> my XP box at home. However whenever I get back into the office the >>>> monitor on the Vista machine is on. Clearly the power saving and/or >>>> screensaver has been disabled by the remote desktop connection. >>>> >>>> This is certainly not "green", and eventually may give me some burn in >>>> problems on the monitor (OK, that may take too long to worry about). >>>> >>>> Is there a setting I've missed somewhere? >>>> >>>> Cheers, >>>> >>>> John. >>> >> > > |
| | #6 (permalink) |
| | Re: Vista Remote Desktop disables monitor power saving. Hello Cap'n, I tried that and it made no difference whatsoever. Thanks for the tip though. /john "Tiberius" <James@tiberius.kirk> wrote in message news:uQRSP9TmHHA.3588@TK2MSFTNGP02.phx.gbl... > Hello.. > > the problem existed in XP and now perhaps its still in Vista > > Here is a registry edit that enables the power off for XP when in the > welcome screen mode > after someone logs in remotely. I have not tested it yet with vista.. but > you may want to try it > after you make a restore point of course: > > copy the exact text into a notepad file and rename the file to have a .reg > extension, > then double click it to enter it into the registry.... > > As I said, I didn't have the chance to test it on vista yet.. so if you > try it please tell us if this resolved your problem. > > Copy paste the below code: > ------- > > Windows Registry Editor Version 5.00 > > [HKEY_USERS\.DEFAULT\Control Panel\Desktop] > "PowerOffActive"="1" > "ScreenSaveActive"="1" > "SCRNSAVE.EXE"="(None)" > > > > > > > "JohnD" <johnd@dyalog.com> wrote in message > news:uM8dUvTmHHA.1776@TK2MSFTNGP05.phx.gbl... >> OK Rick, >> >> Not ideal, but it's "greener" that way too. >> >> I do have "shut down monitor after 10 minutes" set, but when I come in it >> is on and displaying the local login screen. But, if as you say, it's >> "difficult to discern" why its failing I'll go with the power switch. I'd >> guess that its a bug in Vista somewhere though (or perhaps in the video >> drivers). >> >> /john >> >> >> "Rick Rogers" <rick@mvps.org> wrote in message >> news:eprG2lTmHHA.3888@TK2MSFTNGP03.phx.gbl... >>> Hi John, >>> >>> Vista should revert to default power settings when you log on remotely >>> as when you do it goes to the logon screen locally. When you logoff it >>> should remain at the local logon screen. If power settings for the >>> system are set to shut down the monitor or go to a screensaver then >>> these should kick in. Something may be interfering with this process, >>> but can be difficult to discern. If you are concerned with this, you may >>> want to simply turn the monitor off when you leave the office. >>> >>> -- >>> Best of Luck, >>> >>> Rick Rogers, aka "Nutcase" - Microsoft MVP >>> http://mvp.support.microsoft.com/ >>> Windows help - www.rickrogers.org >>> My thoughts http://rick-mvp.blogspot.com >>> >>> "JohnD" <johnd@dyalog.com> wrote in message >>> news:ePlbAgTmHHA.3588@TK2MSFTNGP02.phx.gbl... >>>> Hello All, >>>> >>>> I can connect fine to my office Vista machine (via Remote Desktop) from >>>> my XP box at home. However whenever I get back into the office the >>>> monitor on the Vista machine is on. Clearly the power saving and/or >>>> screensaver has been disabled by the remote desktop connection. >>>> >>>> This is certainly not "green", and eventually may give me some burn in >>>> problems on the monitor (OK, that may take too long to worry about). >>>> >>>> Is there a setting I've missed somewhere? >>>> >>>> Cheers, >>>> >>>> John. >>> >> > > |
| External Monitor Disables Screen Saver and Power Plan | Vista hardware & devices | |||
| Vista and Monitor Power Saving | Vista General | |||
| Vista and Monitor Power Saving | Vista hardware & devices | |||
| can you prevent monitor power saving during video playback? | Vista music pictures video | |||
| Power Saving Options - LCD Monitor | Vista General | |||
