| | vista netgear wireless problem i have previously installed vista about 2 months ago and couldnt connect with my wireless(i have all the correct drivers etc) and went back to xp...what i find a little confusing is the passphrase/key bit which i think is the reason i cant connect...if i reset my router will i be able to use the default netgear passphrase of admin/password when setting up the wireless section in vista?any help would be much appreciated,thankyou |
| Netgear Wireless Virgin Router Problem | Network & Sharing | |||
| vista and wireless netgear card | Vista General | |||
| connecting to a wireless router using netgear vista | Vista networking & sharing | |||
| vista netgear wireless cant connect | Vista networking & sharing | |||
| About using Netgear wireless adaptor's software in Vista beta 2 | Vista networking & sharing | |||
