Vista - WMDC will not start up - EnableRAPIMgr(0x80070005) error
Old 05-19-2007   #1 (permalink)
astromusic
Hi, I am trying to use my Cingular 8125 (HTC Wizard) device to sync to my
Vista Ultimate computer. I installed the latest version of the WMDC
(drvupdate-x86.exe), in the prescribed manner (connect device, install
software) then disconnect and reconnect the device once the software is
installed. The device shows up as working fine in the Device Manager.
However, if I try to launch WMDC from the control panel, nothing happens.
Investigating the Event Log, I see the error "Failed to start the Windows
Mobile legacy device connectivity service due to EnableRAPIMgr(0x80070005)
failure (see data for failure code).". I have attached the full Event Log
entry at the end, just in case it is meaningful to someone.
I have tried un-installing, restarting, deleting Windows Mobile folder,
re-installing etc., a number of times (at least 5), and every time, the
result is exactly the same. Software installs fine, but WMDC won't start up.
What can I try next?
-Kal.
Log Name: Application
Source: RapiMgr
Date: 5/19/2007 12:37:35 PM
Event ID: 2
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: kal-bigdell
Description:
Failed to start the Windows Mobile legacy device connectivity service due to
EnableRAPIMgr(0x80070005) failure (see data for failure code).
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="RapiMgr" />
<EventID Qualifiers="49152">2</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2007-05-19T19:37:35.000Z" />
<EventRecordID>6297</EventRecordID>
<Channel>Application</Channel>
<Computer>kal-bigdell</Computer>
<Security />
</System>
<EventData>
<Data>EnableRAPIMgr(0x80070005)</Data>
</EventData>
</Event>
Old 11-06-2007   #2 (permalink)
Ultimate x32
Re: WMDC will not start up - EnableRAPIMgr(0x80070005) error
Did you ever get this resolved? I'm having exactly the same problem and can't find any information on it.
error 0x80070005 Vista General
0x80070005 error Vista General
WMDC won't start Vista General
Can't start Windows audio-service error: 0x80070005: Access denied Vista General
Can't Start WMDC Vista General
