| Guest | Task Scheduler Problem I want to run a URL in Task Scheduler. It's an internet radio feed and I want to open it each morning at 6h45, etc... Problem is that Task scheduler do not seem to recognize a URL as a valid action. Any idea how to make it work ? Thanks |
| Guest | Re: Task Scheduler Problem Hello, put 'iexplore' in front of the website. e.g.: iexplore "http://www.jimmah.com/vista/" -- -JB Microsoft MVP - Windows Shell Windows Vista Support FAQ - http://www.jimmah.com/vista/ On Sat, 19 May 2007 22:28:44 -0400, "Junkyard Engineer" <jevandenbroucke@hotmail.com> wrote: >I want to run a URL in Task Scheduler. It's an internet radio feed and I >want to open it each morning at 6h45, etc... > >Problem is that Task scheduler do not seem to recognize a URL as a valid >action. > >Any idea how to make it work ? > >Thanks |
| Guest | Re: Task Scheduler Problem Actually, You have to be a bit more specific than that. Where it says "Program/script", type (with quotes): "C:\Program Files\Internet Explorer\iexplore.exe" And then where it says arguments, put the website you wish to load. -- -JB Microsoft MVP - Windows Shell Windows Vista Support FAQ - http://www.jimmah.com/vista/ On Sat, 19 May 2007 22:35:57 -0400, Jimmy Brush <jb@mvps.org> wrote: >Hello, > >put 'iexplore' in front of the website. > >e.g.: > > iexplore "http://www.jimmah.com/vista/" |
| Guest | Re: Task Scheduler Problem Yeeesss ! It works Thanks ! "Jimmy Brush" <jb@mvps.org> a écrit dans le message de news:4ucv43t26grfd4bpherjegqp424nrbv71u@4ax.com... > Hello, > > put 'iexplore' in front of the website. > > e.g.: > > iexplore "http://www.jimmah.com/vista/" > > -- > -JB > Microsoft MVP - Windows Shell > Windows Vista Support FAQ - http://www.jimmah.com/vista/ > > > On Sat, 19 May 2007 22:28:44 -0400, "Junkyard Engineer" > <jevandenbroucke@hotmail.com> wrote: > >>I want to run a URL in Task Scheduler. It's an internet radio feed and I >>want to open it each morning at 6h45, etc... >> >>Problem is that Task scheduler do not seem to recognize a URL as a valid >>action. >> >>Any idea how to make it work ? >> >>Thanks |
| Task Scheduler Problem | Vista General | |||
| Task Scheduler Problem | General Discussion | |||
| Task scheduler problem | Vista General | |||
| Task scheduler problem : task do not close | Vista General | |||
