| Guest | Screensaver problems - ongoing and intermittant Sometimes my VISTA screensavers work and sometimes they don't. Screensaver problems seem to be a common, if minor, annoyance. Doesn't seem to be related to HID, because I disable that and it doesn't seem to make a difference. How common is this, and what is mighty MS doing about it? |
| Guest | Re: Screensaver problems - ongoing and intermittant Hi, Problems with screensavers aren't inherint, they are caused by background applications or processes that either do not terminate properly or interfere with their initialization. A solution can be found by minimizing what loads at boot and removing applications that are not Vista compatible. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "Harry Krause" <harry.krause@gmail.com> wrote in message news:%23GsgelzmHHA.3736@TK2MSFTNGP03.phx.gbl... > Sometimes my VISTA screensavers work and sometimes they don't. Screensaver > problems seem to be a common, if minor, annoyance. > Doesn't seem to be related to HID, because I disable that and it doesn't > seem to make a difference. > > How common is this, and what is mighty MS doing about it? |
| Ongoing problems with SP1 | Vista hardware & devices | |||
| Ongoing problems with SP1 | Vista installation & setup | |||
| Screensaver problems | Software | |||
| Intermittant Internet/Outlook connection problems | Vista General | |||
| Intermittant internet/Outlook connection problems | Vista General | |||
