| | Error when using Remote Desktop from XP to Vista Enterprise I am using Remote Desktop on an XP laptop with VPN to try to get to my work Vista Enterprise Desktop. From the laptop, I connect to the VPN and then start the remote desktop connection. I get to the desktop and choose my profile and put in my username and password - I then get the error The Trust Relationship between the workstation and the primary domain failed. I can remote from this laptop into other XP machines in the office and used to remote into my work desktop when it was XP using this laptop. I turned off the firewall on the Vista machine to see if that would help, but it didn't - same error. |
| | Re: Error when using Remote Desktop from XP to Vista Enterprise Yes, I have that checked. I actually figured out how to fix it. I removed the Vista machine from the domain and then re-added it and now it works. Thanks! "minimage" wrote: > > From > http://adacosta.spaces.live.com/blog...3DB!9709.entry > > -*I am unable to connect to Windows Vista using Remote Desktop on > Windows XP.* > > Ensure that you enable the option to connect from any version of Remote > Desktop. Click Start > type System > select and click it > click the > Remote Settings link under Tasks > under Remote Desktop, select the > Allow connections from computers running any version of Remote Desktop > (less secure) radio box > click OK. - > > > -- > minimage > |
| Remote Desktop Error - Vista to XP - after log in | Vista networking & sharing | |||
| Remote Desktop Error | Vista networking & sharing | |||
| Remote Desktop Error on Vista (Disconnected) | Vista networking & sharing | |||
| remote desktop error on vista dual screen | Vista General | |||
| Remote Desktop from Vista to XP error message | Vista networking & sharing | |||
