Vista Tutorial - office 2007 running in vista cryptic error in "problem reports and solutions"
Old 05-23-2007   #1 (permalink)
Nicholas Hall
Guest
Sometimes I get a cryptic error in the "Problem reports and solutions" tool
in windows vista.
I am at a loss at what it means and I wondered if anyone knows what it
means.
Problem signature
Problem Event Name: Office11ShipAssert
Problem Signature 01: 4ylr
Problem Signature 02: 12.0.4518.0
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 2057
Extra information about the problem
No2nd: 2
Bucket ID: 38167698
In event viewer I get this
The description for Event ID 5000 from source Microsoft Office 12 cannot be
found. Either the component that raises this event is not installed on your
local computer or the installation is corrupted. You can install or repair
the component on the local computer.
If the event originated on another computer, the display information had to
be saved with the event.
The following information was included with the event:
Office11ShipAssert
4ylr
12.0.4518.0
the message resource is present but the message is not found in the
string/message table
Old 05-23-2007   #2 (permalink)
Dana Cline - MVP
Guest
Re: office 2007 running in vista cryptic error in "problem reports and solutions"
I found something in my startup code labeled Office Shipping Assistant or
something like that...I just removed it from the startup and don't have any
problems with it now <g>.
Dana Cline - MCE MVP
"Nicholas Hall" <niknik1971NoSpAm@btinternetReMoVe.com> wrote in message
news:4DFB6591-B8E9-4987-A7B1-A39B5FAA2E68@microsoft.com...
> tool in windows vista.
> means.
> Problem signature
> Locale ID: 2057
> No2nd: 2
> Bucket ID: 38167698
> be found. Either the component that raises this event is not installed on
> your local computer or the installation is corrupted. You can install or
> repair the component on the local computer.
> to be saved with the event.
> Office11ShipAssert
> 4ylr
> 12.0.4518.0
Old 05-23-2007   #3 (permalink)
Nicholas Hall
Guest
Dana could you tell me where to find the startup code.
NIK
"Dana Cline - MVP" <dcline@scriptpro.com> wrote in message
news:%23JR1xAWnHHA.4316@TK2MSFTNGP06.phx.gbl...
>> means.
>> Problem signature
>> Locale ID: 2057
>> No2nd: 2
>> Bucket ID: 38167698
>> Office11ShipAssert
>> 4ylr
>> 12.0.4518.0
Old 05-23-2007   #4 (permalink)
Cal Bear '66
Guest
msconfig > startup tab?
news:14967185-C016-49C8-A1A1-CF8820517FFD@microsoft.com...
> NIK
>>> in windows vista.
>>> means.
>>> Problem signature
>>> Locale ID: 2057
>>> No2nd: 2
>>> Bucket ID: 38167698
>>> Office11ShipAssert
>>> 4ylr
>>> 12.0.4518.0
Old 05-23-2007   #5 (permalink)
Nicholas Hall
Guest
Thanks Cal, I thought it was a startup code in Office?
What a fool I feel. :-/
Well I had a look in msconfig and there was nothing in there to do with
office in there.
NIK
"Cal Bear '66" <xxx@xxx.org> wrote in message
news:04D3248F-BD2A-4B36-AF36-955FC46DF67C@microsoft.com...
>> NIK
>>>any problems with it now <g>.
>>>> means.
>>>> Problem signature
>>>> Locale ID: 2057
>>>> No2nd: 2
>>>> Bucket ID: 38167698
>>>> cannot be found. Either the component that raises this event is not
>>>> installed on your local computer or the installation is corrupted. You
>>>> can install or repair the component on the local computer.
>>>> had to be saved with the event.
>>>> Office11ShipAssert
>>>> 4ylr
>>>> 12.0.4518.0
Old 05-23-2007   #6 (permalink)
Dana Cline - MVP
Guest
Go to microsoft.com, search for "autoruns". It's a great utility that will
show you what starts up with your PC, and lets you uncheck any you don't
want.
> NIK
>>> means.
>>> Problem signature
>>> Locale ID: 2057
>>> No2nd: 2
>>> Bucket ID: 38167698
>>> on your local computer or the installation is corrupted. You can install
>>> Office11ShipAssert
>>> 4ylr
>>> 12.0.4518.0
Old 05-23-2007   #7 (permalink)
Dana Cline - MVP
Guest
MSConfig doesn't show you all of it. Microsoft's Autoruns utility does a
much better job - it's by the guy from SysInternals.
>> NIK
>>>> means.
>>>> Problem signature
>>>> Locale ID: 2057
>>>> No2nd: 2
>>>> Bucket ID: 38167698
>>>> Office11ShipAssert
>>>> 4ylr
>>>> 12.0.4518.0
Old 05-23-2007   #8 (permalink)
Cal Bear '66
Guest
Good to know.
Thank you.
news:uycijPXnHHA.3968@TK2MSFTNGP06.phx.gbl...
> MSConfig doesn't show you all of it. Microsoft's Autoruns utility does a much
>>> NIK
>>>>> means.
>>>>> Problem signature
>>>>> Locale ID: 2057
>>>>> No2nd: 2
>>>>> Bucket ID: 38167698
>>>>> Office11ShipAssert
>>>>> 4ylr
>>>>> 12.0.4518.0
Old 05-23-2007   #9 (permalink)
Nicholas Hall
Guest
I used the application and I could not find anything resembling the said
file, "Office Shipping Assistant"?
NIK
news:uaq9EPXnHHA.3968@TK2MSFTNGP06.phx.gbl...
> want.
>> NIK
>>>> means.
>>>> Problem signature
>>>> Locale ID: 2057
>>>> No2nd: 2
>>>> Bucket ID: 38167698
>>>> Office11ShipAssert
>>>> 4ylr
>>>> 12.0.4518.0
Vista & Office 2007 Error: "not been installed for the current user" Vista General
Is it safe to delete "Error Reports" in Disk cleanup? Vista performance & maintenance
"problem reports and solutions" control panel does not launch Vista performance & maintenance
Q&A: "Business Value" Launch of Windows Vista, 2007 Office System and Exchange Server 2007 Creates Groundbreaking Opportunities for Partners Vista News
