| | how to turn off narrator?? help! a customer of mine has a vista laptop (ultimate) and the narrator keeps starting itself on every reboot, I can't for the life of me figure out how to stop it form starting, or how to uninstall the damn thing. anyone know how to turn this off? |
| | Re: how to turn off narrator?? help! "Drnick" <Drnick5@cox.net> wrote in message news:1179949081.409495.271580@q75g2000hsh.googlegroups.com... >a customer of mine has a vista laptop (ultimate) and the narrator > keeps starting itself on every reboot, I can't for the life of me > figure out how to stop it form starting, or how to uninstall the damn > thing. anyone know how to turn this off? > Do you get that on the log-in screen? I get that sometimes. What I do when that happens is to press the button in the bottom left corner and select the bottom item, and press OK. Then I press the button again and deselect the item and press OK. Seems to work fine after that, and you can type the password without the narrator speaking again. I put it down to some weird bug. ss. |
| | Re: how to turn off narrator?? help! "Drnick" <Drnick5@cox.net> wrote in message news:1179949081.409495.271580@q75g2000hsh.googlegroups.com... >a customer of mine has a vista laptop (ultimate) and the narrator > keeps starting itself on every reboot, I can't for the life of me > figure out how to stop it form starting, or how to uninstall the damn > thing. anyone know how to turn this off? > Does the customer happen to have a version of MS Office installed that by default installed the Office Toolbar. I believe Office XP was the last version of Office that included it and installed by default. If yes, you can turn off Narrator in the Office Toolbar. -- Michael Solomon Backup is a PC user's best friend DTS-L.Org: http://www.dts-l.org/ |
| | Re: how to turn off narrator?? help! Hello Drnick, Narrator might be set to automatically start on the logon page. If you don't need Narrator at the logon page, here is something you can try: go to Start -> Control Panel -> Ease of Access -> Ease of Access Center, and then, in the left pane, click Change Aadministrative settings. Under System Administrator settings, clear the Apply all settings to the logon desktop checkbox, and then click Save. I hope this helps you with your problem. |
| | Re: how to turn off narrator?? help! press the windows key and U ,, it will pop up ease of access .. then click on where it says use the computer without a display . you can turn off the narroator in there .. "Drnick" <Drnick5@cox.net> wrote in message news:1179949081.409495.271580@q75g2000hsh.googlegroups.com... >a customer of mine has a vista laptop (ultimate) and the narrator > keeps starting itself on every reboot, I can't for the life of me > figure out how to stop it form starting, or how to uninstall the damn > thing. anyone know how to turn this off? > |
| | #6 (permalink) |
| | Re: how to turn off narrator?? help! thanks ever so much rosie!!!!!!!!! "Rosie" wrote: Quote: > press the windows key and U ,, it will pop up ease of access .. then click > on where it says use the computer without a display . you can turn off the > narroator in there .. > > > "Drnick" <Drnick5@xxxxxx> wrote in message > news:1179949081.409495.271580@xxxxxx Quote: > >a customer of mine has a vista laptop (ultimate) and the narrator > > keeps starting itself on every reboot, I can't for the life of me > > figure out how to stop it form starting, or how to uninstall the damn > > thing. anyone know how to turn this off? > > > |
| | #7 (permalink) |
| Vista Home Premium 32bit | Re: how to turn off narrator?? help! Thanks Phil777, Worked like a charm. |
| How can I turn off Narrator? | Vista performance & maintenance | |||
| Narrator won't turn off | Vista General | |||
| Narrator - Turn On or Off | Tutorials | |||
| turn off narrator | Vista General | |||
| How do I turn off Narrator? | Vista General | |||
