| | WLM - No sound out I am running Vista Ultimate and WLM 8.1 with a Logitech Communicate STX. In the Audio and Visual Setup wizard everything works fine. (I can also record and playback audio and visual.) When a connection is made everything works except for my sound. None is generated and the microphone volume bar shows no activity. (The same camera works just fine with WML on my laptop.) Any suggestions gratefully received. Nitram |
| | Re: WLM - No sound out Control Panel > Sounds >Recording tab Set the microphone as default and click the Configure and Properties buttons to set it up. "Nitram" <Nitram@discussions.microsoft.com> wrote in message news:129E980F-EECD-4F72-BDC0-626F0B817EDE@microsoft.com... >I am running Vista Ultimate and WLM 8.1 with a Logitech Communicate STX. In > the Audio and Visual Setup wizard everything works fine. (I can also record > and playback audio and visual.) > When a connection is made everything works except for my sound. None is > generated and the microphone volume bar shows no activity. (The same camera > works just fine with WML on my laptop.) > > Any suggestions gratefully received. > > Nitram |
| | Re: WLM - No sound out Thanks for the suggestion, but it is already set as the default recording device. Nitram "Cal Bear '66" wrote: > Control Panel > Sounds >Recording tab > Set the microphone as default and click the Configure and Properties buttons to > set it up. > > > > "Nitram" <Nitram@discussions.microsoft.com> wrote in message > news:129E980F-EECD-4F72-BDC0-626F0B817EDE@microsoft.com... > >I am running Vista Ultimate and WLM 8.1 with a Logitech Communicate STX. In > > the Audio and Visual Setup wizard everything works fine. (I can also record > > and playback audio and visual.) > > When a connection is made everything works except for my sound. None is > > generated and the microphone volume bar shows no activity. (The same camera > > works just fine with WML on my laptop.) > > > > Any suggestions gratefully received. > > > > Nitram > > |
| | Re: WLM - No sound out And you've gone through the Tools > Audio and video setup... in Windows Live Messenger? "Nitram" <Nitram@discussions.microsoft.com> wrote in message news:97536910-C329-4991-98EF-BA61E2EDE2F2@microsoft.com... > Thanks for the suggestion, but it is already set as the default recording > device. > > Nitram > > "Cal Bear '66" wrote: > >> Control Panel > Sounds >Recording tab >> Set the microphone as default and click the Configure and Properties buttons >> to >> set it up. >> >> >> >> "Nitram" <Nitram@discussions.microsoft.com> wrote in message >> news:129E980F-EECD-4F72-BDC0-626F0B817EDE@microsoft.com... >> >I am running Vista Ultimate and WLM 8.1 with a Logitech Communicate STX. In >> > the Audio and Visual Setup wizard everything works fine. (I can also record >> > and playback audio and visual.) >> > When a connection is made everything works except for my sound. None is >> > generated and the microphone volume bar shows no activity. (The same >> > camera >> > works just fine with WML on my laptop.) >> > >> > Any suggestions gratefully received. >> > >> > Nitram >> >> |
| | Re: WLM - No sound out Sorry...reread your message and saw that you had already tried that. Have you tried other messenger software (Yahoo or AIM)? "Nitram" <Nitram@discussions.microsoft.com> wrote in message news:97536910-C329-4991-98EF-BA61E2EDE2F2@microsoft.com... > Thanks for the suggestion, but it is already set as the default recording > device. > > Nitram > > "Cal Bear '66" wrote: > >> Control Panel > Sounds >Recording tab >> Set the microphone as default and click the Configure and Properties buttons >> to >> set it up. >> >> >> >> "Nitram" <Nitram@discussions.microsoft.com> wrote in message >> news:129E980F-EECD-4F72-BDC0-626F0B817EDE@microsoft.com... >> >I am running Vista Ultimate and WLM 8.1 with a Logitech Communicate STX. In >> > the Audio and Visual Setup wizard everything works fine. (I can also record >> > and playback audio and visual.) >> > When a connection is made everything works except for my sound. None is >> > generated and the microphone volume bar shows no activity. (The same >> > camera >> > works just fine with WML on my laptop.) >> > >> > Any suggestions gratefully received. >> > >> > Nitram >> >> |
| | #6 (permalink) |
| | Re: WLM - No sound out No I haven't. I only have one contact (poor, lonely me :-)) and am reluctant to ask him to install other software. "Cal Bear '66" wrote: > Sorry...reread your message and saw that you had already tried that. > Have you tried other messenger software (Yahoo or AIM)? > > > "Nitram" <Nitram@discussions.microsoft.com> wrote in message > news:97536910-C329-4991-98EF-BA61E2EDE2F2@microsoft.com... > > Thanks for the suggestion, but it is already set as the default recording > > device. > > > > Nitram > > > > "Cal Bear '66" wrote: > > > >> Control Panel > Sounds >Recording tab > >> Set the microphone as default and click the Configure and Properties buttons > >> to > >> set it up. > >> > >> > >> > >> "Nitram" <Nitram@discussions.microsoft.com> wrote in message > >> news:129E980F-EECD-4F72-BDC0-626F0B817EDE@microsoft.com... > >> >I am running Vista Ultimate and WLM 8.1 with a Logitech Communicate STX. In > >> > the Audio and Visual Setup wizard everything works fine. (I can also record > >> > and playback audio and visual.) > >> > When a connection is made everything works except for my sound. None is > >> > generated and the microphone volume bar shows no activity. (The same > >> > camera > >> > works just fine with WML on my laptop.) > >> > > >> > Any suggestions gratefully received. > >> > > >> > Nitram > >> > >> > > |
| | #7 (permalink) |
| | Re: WLM - No sound out saw this posted-don't know if will help: -quote We've found the cause for an issue in Vista where the microphone/speaker device will not work in Video Call (even though it works in Voice Call and other applications). For this particular issue, the work around is as follows: - Launch the tuning wizard via Tools->Audio and Video Setup - On Step 1: Speaker Setup, make sure the checkbox "Click here if you are using headphones" is NOT checked. We will be adding the fix into a future release. - Duoc [MSFT] - msgrv2@microsoft.com -end of quote "Nitram" <Nitram@discussions.microsoft.com> wrote in message news:33302253-E22A-415B-A561-1F5C4B63E5BE@microsoft.com... | > "Nitram" <Nitram@discussions.microsoft.com> wrote in message | > news:97536910-C329-4991-98EF-BA61E2EDE2F2@microsoft.com... | > >> "Nitram" <Nitram@discussions.microsoft.com> wrote in message | > >> news:129E980F-EECD-4F72-BDC0-626F0B817EDE@microsoft.com... | > >> >I am running Vista Ultimate and WLM 8.1 with a Logitech Communicate STX. In | > >> > the Audio and Visual Setup wizard everything works fine. (I can also record | > >> > and playback audio and visual.) | > >> > When a connection is made everything works except for my sound. None is | > >> > generated and the microphone volume bar shows no activity. (The same | > >> > camera | > >> > works just fine with WML on my laptop.) | > >> > | > >> > Any suggestions gratefully received. | > >> > | > >> > Nitram -- mae |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
No sound when playing music or video, but internet sound works fine | Sound & Audio | |||
| Setting per Application Sound Output, or Per Sound Type Outputs... | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
