My cap lock/num lock icons have disappeared from the notification area/sys
tray but they are 'enabled' in the options and set to display always; but
they dont.
Any ideas how to fix this?
Thanks
Visintini
they dont.
Thanks
Visintini
that program is not part of vista
is you computer a laptop?
did you upgrade from xp?
"Visintini" <Visintini@discussions.microsoft.com> wrote in message
news:4FA77686-F708-4C38-8129-7CC33D361739@microsoft.com...
> they dont.
> Thanks
> Visintini
I would actually LIKE to remove the scroll lock, num lock, and cap lock icons
from my system tray. Any idea how to do that?
> > they dont.
> > Thanks
> > Visintini
If you're using something other than a plain jane keyboard, look in the
keyboard properties in Control Panel.
"Toughskinn" <toughskinn@hotmail.com> wrote in message
news7725EE9-B3F5-4749-AC70-C4DFA600C85A@microsoft.com...
icons
> > area/sys
> > but
> > they dont.
> > Thanks
> > Visintini
Can you figure out what program is running them? This isn't a Windows function. Try right-clicking the icons.
Does that offer any Options, or the ability to Exit?
"Toughskinn" <toughskinn@hotmail.com> wrote in message news7725EE9-B3F5-4749-AC70-C4DFA600C85A@microsoft.com...
>> > they dont.
>> > Thanks
>> > Visintini
I am using the OEM HP keyboard, and there isn't anything in keyboard
properties for removing those icons.
> icons
> > > area/sys
> > > but
> > > they dont.
> > > Thanks
> > > Visintini
No, icons don't respond to any clicks. I have no idea what program is feeding
them.
> >> > they dont.
> >> > Thanks
> >> > Visintini
Odd.
You might try asking in the HP forums:
http://forums1.itrc.hp.com/service/f...e.do?forumId=2
(You have to register to post, but you might find the problem already asked
and aswered in the appropriate section for you model.)
Val
news:1CE38F26-AF7A-492F-A427-D9652B474816@microsoft.com...
>> icons
>> > > area/sys
>> > > but
>> > > they dont.
>> > > Thanks
>> > > Visintini
The answer is NO and YES. No it is not a lap top and yes I did upgrade from
XP but thanks anyway, I un-instaled and re-installed the keyboard software
and this fixed it!
Visintini
> they dont.
> Thanks
> Visintini
| Similar Threads | ||||
| Notification area/ How to get rid of Caps Lock, Scroll Lock | Heidi | Vista General | 6 | 27 Mar 2009 |
| f lock | Wasted | Vista General | 10 | 14 Nov 2008 |
| CAPS lock / SHIFT lock difficulty | Dumb Bunny | Vista General | 1 | 22 Apr 2008 |
| Num Lock always off | Jeff | Vista General | 10 | 01 Apr 2007 |
| Lock Down | Shamanarts | Vista General | 2 | 15 Mar 2007 |
